Results 21 to 24 of 24
02-04-2021, 10:53 AM #21
- Aug 2020
- United Kingdom
- 249
I don't have a problem with ABS per-se but standard ABS warp a lot because they shrink a lot on cooling so a part like the one you wish to make will be very difficult in ABS that is why we went to the Dutch filament ABS-x the retailer I buy it from is 3Dfilaprint they say they have a USA presence now but I don't have any contact details for them. When we first started I bought a basic ABS filament from Amazon but we have never been able to get large prints from it. Hence ABS-x and so called low warp technology!Pretty much indistinguishable for ABS once printed is PET-G and is much easier to print because of low warp/shrinkage on cooling. Once more we use a premium filament from the Mitsubishi Dutch unit. 3dfilapint if you can find their US number also stock this material as an own brand. A quick email to Customer Service: cs-3dp@mcpp-europe.com should get you a US supplier of their Filaments. If you need any more help please let me know I am always ready to help.
02-04-2021, 10:57 AM #22
- Jan 2021
- Southern Maryland
- 16
02-04-2021, 12:34 PM #23
- May 2018
- 561
I use a M3 .5 I think it is.. standard M3 find thread you would have on a 3d printer extruder motor and what not.. Have a big bag of mushroom head screws I bought off ebay. also use M4 for larger parts. Have had no luck tapping any other plastic PLA Nylon PETG.. PLA works but not clean like ABS. I put the tap in a cordless drill and run it into a preprinted hole the is sized just slightly smaller than you would drill in metal for the tap. I use compressed air to blow the plastic out of the hole as the tap advances and is retracted. For short standoffs I model the tap hole all the way through so I can run that tap in from the bottom where there are no walls in the way of the drill chuck
In the photo I printed the lid in clear PETG so I can see the built in LEDS on the Trinket board, eliminating the need to add external LEDS
Next I need to print a dial for the 4 switch positions I will be using.
12-13-2021, 01:41 PM #24
- Dec 2021
- 12
Anycubic experience
Purchased a 4Pro 2.0, they took the money but never shipped the product.... see trustpilot before you waste your money !
QIDI Slicer "Plater" is...
