07-23-2014, 02:30 PM #1
I need a piece of PTFE id=3mm od=8mm
Hello everybody! I need to replace a piece of PTFE in my hot-end. I'm running 3mm filament. So I'm not sure, but the inner diameter needs to be a little larger than 3mm and the outer diameter needs to be 8mm. And it needs to be at least 30mm long.
I can't find anything suitable. I've checked all the usual places including eBay. Can anybody point me in the right direction?Last edited by Roxy; 07-23-2014 at 02:56 PM.
07-23-2014, 04:22 PM #2
- Jun 2014
- Burnley, UK
- 1,662
I tend to find that when searching for PTFE you get better results with "Teflon".
http://www.ebay.com/itm/4067-TEFLON-...item2c7256261e
07-23-2014, 04:53 PM #3
Thank You for the tip! That did the trick!
QIDI Slicer "Plater" is...
