Results 1 to 10 of 13
Thread: Cleaning the bed
12-31-2020, 10:53 AM #1
Cleaning the bed
Besides alcohol, being in short supply, what's good to use for cleaning the bed.
I have an Ender 3pro. I have acetone but I understand that will melt the bed.
12-31-2020, 02:09 PM #2
Cheapest possible window cleaner you can get. That way there is not other chemicals that could render cleaning useless.
12-31-2020, 02:45 PM #3
We have Dawn, which is what we use for most things. A little white vinegar. I'll give that a try. It works on astronomy equipment and windows, so it should be ok.
I'll report back.
TNX
12-31-2020, 06:35 PM #4
I was just looking Walmart online store has some and the price is not too bad!
Isopropyl.jpgLast edited by Roberts_Clif; 01-23-2021 at 09:43 AM.
01-15-2021, 08:23 PM #5
I have a cleaner. My Wife.
This isn't a business environment.
I tried the Distilled water, vinegar, Dawn mix. Then rinsed with distilled water.
I ended up putting my new surface on. I'll try again.
01-25-2021, 07:17 AM #6
what is the surface ?
And what kind of dirt do you have ?
I find that mostly I just wipe the dust off :-) And occasionally leaves that blow through the windows facing the printers.
For everything else a quick wipe with a sheet of kitchen paper dampened with acetone is all I've ever used.
Given how fast it evaporates and how little you need - it's just not there long enough to damage even a susceptible print surface.
Not sure how a print bed can get really greasy or dirty ?
What are you guys doing to them ?
01-30-2021, 07:27 AM #7
- Aug 2020
- United Kingdom
- 249
The only time I use anything other than a quick wipe with Acetone is on surfaces which I have used glue stick which when they get scruffy I put a drop of washing up liquide on the surface and wash off under a tap with water, dry, then wipe over with IsoPropyl Alcohol
04-13-2021, 04:59 PM #8
Umm, ok.
I've settled on a quick wipe with a towel lightly dampened with Acetone.
It also helps to keep your fingers off the bed. Skin oils can affect bonding to the bed.
04-21-2021, 10:49 AM #9
04-22-2021, 09:04 PM #10
I'm wondering what Lisa is chatting about. Lol
