    Align model face with print bed?
    HiI have a Dremel 3D45 printer and am using the Dremel 3D slicing software which is based on Cura. Does anyone know if it is possible to align a specific face of the model to the print bed. I have looked but cant find an easy way to do this.Cheers
    Engineer-in-Training
    Jul 2020
    Monterey Bay, California
    Add jamcultur on Thingiverse
    If it's Cura, you should be able to select the model, then click on the "Rotate" icon on the left side of the window and rotate it to the orientation you want. If the model ends up above the build plate, click "Lay flat".
    Brilliant, thanks for your help, could not find that option for looking
