Thread: help is needed anet ET4?
08-28-2020, 10:53 AM #1
- Mar 2020
- 7
In the “home” and “automatic calibration” options, the final stop of the z axis did not find an end. The hot bedSpeed Test essay writer and extruder went in the opposite direction to the final stops. At the same time, the 3D printer began to make loud noises.What to do, will the firmware fix this problem?
08-28-2020, 12:45 PM #2
yes it should.
2 things. check that you have the endstops plugged into the '-' socket. so -x -y -z
Most modern boards have 6 endstop sockets so that you can have max and min endstops- so make sure you are using the right ones.
In the configuration file make sure you are homing to '0' - as that will correspong to the '-' soclek on the board.
having spent some time this week looking through configuration.h files - it's definitely an option.
So hopefully between those two things you should find the answer :-)
01-11-2021, 01:36 PM #3
- Jan 2021
01-13-2021, 03:02 PM #4
- Jan 2021
New - can't get started.
Today, 11:40 AM in General 3D Printing Discussion
