07-13-2020, 04:25 PM #1
- Jul 2020
Using PETG with X-Plus white side of build surface
Hello,
After destroying 2 bed surfaces by printing PETG on the white side with a bed temp of 80 degrees C (could not get the model off-ripped the white sticker), I dialed the bed temp back to 30 degrees C and I was able to get a fairly simple release.
Does anyone else use the white side of the build surface for PETG?
If so, what are your settings?
Are there any issues with printing PETG with a near ambient bed temp?
I tried using the smooth side - but even up to 90 degrees C with or without glue, but I could not get the model to stick.
11-12-2020, 08:06 AM #2
- Nov 2020
- 6
I use the white side with PETG but I alway coat the bed with a glue stick and haven’t had a problem removing the print. I use the default PETG settings from the QiDi slicer.
01-08-2021, 08:29 AM #3
- Jan 2021
- Sydney Australia
The Qidi flexible build surface is great till the white side starts to bubble and lift, happens faster when printing high temps for long periods.
I ditched it and went with a bosciliarite glass bed, always use Dimaflex adhesive and have never looked back.
Which 3d printer for small...
