02-23-2020, 10:41 AM #1
- Dec 2016
- 43
Marlin manual Bed leveling Leveling increment tweaking
Using a Makerfarm Pegasus 8 which in turn is Using Marlin Firmware 1.x, trying to improve my accuracy and was wondering if there is a way to tweak my setting for the manual leveling process.
When performing a manual bed level, when i turn the knob the x carriage moves up or down at .5mm increments (I think) is there anyway i can lower the number to .25mm or .1mm.
Perhaps I'm being anal, but I like to be as close to possible when running the process.
Thanks
02-24-2020, 12:38 PM #2
Are you looking for
#define MBL_Z_STEP 0.025 // Step size while manually probing Z axis.
02-24-2020, 01:43 PM #3
- Dec 2016
- 43
ah looks like you also found my post on: http://www.3dprintingforum.us/viewto...p=16113#p16113
Perhaps, is this line already in the Marlin Config.h or am I adding it? Conversely is there a way to do it via Pronterface and gcode commands?
I don't like posting every where, but seems like a lot people don't know what I'm asking. or that the solution is so incredibly simple they don't bother
02-24-2020, 03:35 PM #4
I found it in all versions of marlin 1.1.x that I have programmed for My 3D Printer.
