Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Begginer, need advice
    So i just got my ender 3 pro over the weekend. Ran a few prints using cura, and everything seemed to be working good with the filament provided. I bought some Overture PETG, on accident, and tried running with it, never got a print to work. So I returned that stuff and got Overture PLA this time...shew. I also upgraded my extrusion mechanism from the original plastic to the grey metal one, with the blue capricorn PTFE tubing. Along with that, i replaced the bed springs. I added a couple pictures. 1 you can see is just horrible, and the the one that looks decent is what i created and printed the day i got the printer. Sorry, it's purdue...LOL....if anyone can give me some insight on this i would greatly appreciate it. If there is a way to grab all the settings from cura let me know, and i will capture the settings and share.Thank you in advance
    i should mention that have ran the bed levling several times using Ender-3_Bed-leveling_procedure
    Student 3DKrysh's Avatar
    Feb 2020
    Riga, Latvia
    Hi!
    On the purple print, it could be that the printbed is not in level. One side of the badge looks a bit too high. Also, at what temperatures / speed are you printing?
    I have tried several temps. 200/60....210/60...same temps with bed at 50 instead of 60. Print speed has been set at 50
    i just recieved the glass plate for it as well. I will try some more printing after i level it here....hope it works.
    Feb 2020
    Riga, Latvia
    You can also try to reduce speed for the first layer. Most slicers have this options, so try to print the first layer at 25mm/s for example and the rest at 50mm/s. Also, if you have trouble getting smaller parts, you can try to print a huge rectangle outline (some 2 perimeters) to better see where the bed
    Hi!
  8. #8
    Engineer Roberts_Clif's Avatar
    Jun 2017
    Washington State, USA
    Quote Originally Posted by MR Pink View Post
    Setting up the Slicer is almost as important as the 3D Printer Firmware itself.
    I find looking at everyone's slicers settings help me greatly in setting up my own.
    Saving your slicers settings is as simple as clicking on File Menu "saving profile" in the older Cura
    OR
    Clicking on Settings "Profile", "Manage Profiles", Select Profile and Export in Newer Version of Cura.
  9. #9
    Thank you all for the comments. After tinkering with it....lots of videos, bltouch install, glass build plate I have had several good prints now. Still.a little issue with sticking to the bed, but I have been using the raft to help with that issue. Will be trying the hairspray or glue to reduce the filament waste. I am also going to be upgrading the main board. I will post more after that install here in a week or so. I will add some pictures of my prints shortly
  10. #10
    Jun 2017
    I also find that cleaning the Bed with isopropyl alcohol help me greatly in keeping good 1st layer adhesion with my bed material.
