Results 1 to 6 of 6
Thread: Zortrax M200-Pythone Flex
02-05-2020, 08:17 AM #1
- Feb 2020
- 3
Hello everybody,I have a problem with printing TPU filament Python Flex on my Zortrax M200. I know it's not dedicated for my printer, but does anybody have some experience using this filament on this printer? I tried recommended settings for this material in Z SUIT but it just doesn't print well. If anybody has some tip or experience please help me Thank you
02-07-2020, 10:15 AM #2
slower printing speed, 1.3mm retraction at 30mm/s and higher printing temperature
02-10-2020, 02:43 AM #3
02-10-2020, 11:29 AM #4
Also talk to SirFloyd - he's just been all through the flexible filament setup on a zortrax. https://3dprintboard.com/member.php?34060-SirFloyd
02-11-2020, 07:28 AM #5
- May 2019
- 6
Hey Jugrina,These are my settings for printing (Infill is of course dependant on what kind of properties are you looking for). I still get some stringing between the models, but the printing is really clean, almost as good as rigid materials.
https://imgur.com/a/vmKVWoP
Support: 30°
Material: FLEX-based filament
Nozzle diameter: 0.4 mm
Layer: 0.19 mm
Quality: Default
Infill: Solid
Fan speed: 100%
Seam: Normal
Surface layers Top: 8
Surface layers Bottom: 5
Max. wall thickness: 3.13 mm
First layer Density: 100%
First layer Print speed: 50%
First layer Flow ratio: 100%
First layer gap: 0.37 mm
Raft Enabled: Yes
Raft layers: 4
Platform-raft gap: 0.28 mm
Raft Density: 100%
Raft Print speed: 100%
Raft Flow ratio: 100%
Print speed: -50%
Extruder flow ratio: -3%
Top layer infill (%): 100
Bottom layer infill (%): 100
Extrusion temp.: 233
Platform temp.: 65
Retraction speed: 34
Retraction distance: 0.8
Support Density: 2.50 mm
Gap XY: 0.36
I used raft, becouse the model is really tall and needs extra support. Also i have a larger XY gap, becouse i needed to remove the raft - you are gonna have to play with that.The bottom was still ugly in the end so i just cut it on a table saw.Also, always have fan speed on MAX. And printing speed on lowest possible. The other most important thing is retraction speed and distance.Hope this helps you.
02-12-2020, 02:47 AM #6
- Feb 2020
- 3
Thank you, it works
Which 3d printer for small...
