Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    trying to have build no one is helping
    I am trying to have this made https://photos.app.goo.gl/5aXjN5aURSE1KDpUAThe video is not correct though in design The last designer stopped herehttps://photos.app.goo.gl/CdcbYLTzETe1BMEe9the center is supposed to be bigger and touch the one tooth and the outer ring and the center ring is supposed to push it over and back upif anyone can help id appreciate it its the only one tooth gear in the world so I hope someone is interested
  2. #2
    Engineer-in-Training
    Jun 2014
    I would expect that no one is helping, because the information provided is insufficient to create the model. The images I've seen show a planetary gear set in which there is a supplemental part driven by the gear set that spins. It looks somewhat like a flag or pointer on a shaft spun by the gearset. It does not look like a single-tooth gear, which is an engineering impossibility. The closest mechanical system I can imagine is the escapement mechanism of a clock, but that is a two tooth structure and is not a rotating system.
  3. #3
    Are you offering me help to complete it or just commenting
  4. #4
    Jun 2014
    If you can provide better drawings or an external reference to better represent your project, I am willing to help. The hand sketches are insufficient to create a part/model. The reference to the other person's creation is blurry and indistinct and shows, as I've noted, a planetary gearset driving a shaft with a flag/pointer attached. None of this represents a one tooth gear.
    https://www.youtube.com/watch?v=NjkxXOxhNkE
    the above video presents itself as a pair of single tooth gears, but the sole comment in the video denies that claim.
    An internet search for "single tooth gear" returns nothing.
    More accurate information is required.
  5. #5
    Ok this is the one tooth that is supposed to be where the flag is.
    https://photos.app.goo.gl/39nM1EF1UGfogfNy9
  6. #6
    It's supposed to have more of a curve like this
    https://photos.app.goo.gl/qrVHBtwjYkda2oQX9
    Simple to understand why but the designer won't listen
  7. #7
    Jun 2014
    A wonderfully fuzzy image with unreadable dimensions of what appears to be a rotating cam with a sharp profile is not a gear, but I suppose it's a start in the right direction. I'm going to bow out of this project, as it remains in the currently-impossible category in my estimation.
  8. #8
    You didn't even give it a chance
    It's just a planetary with a large sun
    Fine but you didn't try
  9. #9
    Jun 2014
    I don't believe I'm doing this, but does this linked video from 0:08 to 0:30 seconds have any resemblance to your objective:
    https://youtu.be/mkQ2pXkYjRM?t=8
  10. #10
    I found what I need and it's this
    https://www.youtube.com/watch?v=P-Obt-9tZVo
    I will pass you the 10000:1 in a minute
