Thread: not getting the answeer i need
01-07-2020, 04:38 PM #1
- Jun 2015
- 46
so im trying to have this builthttps://anime.kenmaz.net/view/anime/2941455I had this person do thishttps://photos.app.goo.gl/Ktwx59UtKjpPKVnXAI said great and paid him and now he stopped doing the joband on top of it he showed me he could do it in under 10 minutesif anyone can help me complete this I would appreciate itit will make 20:1 and higher per turn of the wheelit will make what was once 10:1 into 20:1 and moreI hope someone is interested
01-07-2020, 04:41 PM #2
- Jun 2015
- 46
so im trying to have this builthttps://anime.kenmaz.net/view/anime/2941455I had this person do thishttps://photos.app.goo.gl/Ktwx59UtKjpPKVnXAI said great and paid him and now he stopped doing the joband on top of it he showed me he could do it in under 10 minutes if anyone can help me complete this I would appreciate it it will make 20:1 and higher per turn of the wheel it will make what was once 10:1 into 20:1 and more I hope someone is interestedI coudnt edit it for some reason
01-08-2020, 07:03 AM #3
why is everything you do on the forum duplicated 3 three minutes after the first thing ?
It's really annoying :-)
the second link does not work and the drawing makes - literally - no sense.
Also what is the basis of this obsession with gearing ?
I am genuinely intrigued.
Fairly sure if I had the faintest idea what you wanted making it wouldn't be difficult to design and make - but the pictures just don't make any sense.
01-08-2020, 07:32 AM #4
- Jun 2015
- 46
Thanks so much
I don't know why it's keeps repeating
If you can help I'm sure it's a win for both of us with new gear ideas
I have a 100:1 gear reduction
I'm using for a wind generator project
The shaft is 2.68mm by 3mm
Here's the 100:1 reduction
https://photos.app.goo.gl/2NGvMG62cU1Qnvvw7
https://photos.app.goo.gl/5aXjN5aURSE1KDpUA
Please tell me if you can make this work with the shaft
I wanted to know also if you can make it with a higher reduction
From what I've seen this is the very best 100:1 reduction for a wind project ever
If it can do 1000:1 that would be amazing
I'm always looking for the most reduction as possible
Thanks for responding
And I don't know why it keeps repeating
I hope I can fix it on my end
Thanks again
01-08-2020, 10:31 AM #5
- Sep 2015
- 13
A few comments.
If the second link is what someone offered you as a solution, its as good as useless. You are looking for a planetary gear system and the image that was sent to you is a useless joke. Please realize that gears are very complicated geometry - something that simply looks like a triangular tooth will not mesh correctly.
You seem to be all over the place in terms of what you are looking for. In the first post you are asking for 20:1 or more reduction, but then later on you show that you already have a 100:1 reduction. So why not just use the 100:1 if you are looking for the highest gear reduction possible? Are there other parameters you need to hit? Is there something more to this project you haven't mentioned?
What is your end goal? Are you looking to get this only designed? Are you looking to get it designed and 3D printed? What is your budget for this project? Where are you located?
If you are still looking for someone for this project, feel free to PM me with the info above. I take on side projects once in a while.
Which 3d printer for small...
03-27-2024, 05:24 PM in General 3D Printing Discussion
