11-20-2019, 05:53 AM #1
- Nov 2019
3d printed pin socket that requires no soldering?
I'm trying to reduce parts in a build and wondered if it's possible to make a pin socket that does not require soldering and the pin is in contact with the wire itself? When I say pin I mean like a gpio pin. I have an idea in mind where the wire is squeezed in place and the stripped end of the wire is supported by a flexible section of the print that applies pressure towards the pin. Have anybody done something like this? I think the design would work but I'm sceptical about printing flexible sections that would not brake or deform over time.
11-20-2019, 09:32 AM #2
flexible filaments - in my experience - are virtually indestructible.
Should work fine.
11-20-2019, 09:41 AM #3
- May 2018
- 561
I would say, there is a very good reason why contacts are either soldered or crimped..
Just the first thing returned from "Why electrical connections need mechanical contact"
