  1. #1
    Perspective on the print specs for this design using a Flashforge Creator Pro
    Hi there
    Just posting this thread for a quick perspective on what sort of settings I should use to print the attached model. Originally someone else made one for me in about 9 hours with the same model of printer, which I am having difficulty understanding as it is projected to take me about 23hours?
    Appreciate any advice.
    Attached Files Attached Files
  2. #2
    Engineer Roberts_Clif's Avatar
    Jun 2017
    Location
    Washington State, USA
    Do not have a Flashforge Creator Pro though test my settings and can print in just over half that time.
    Layer height .28
    Shell thickness .4
    Top/Bottom thickness .56
    Fill density 22%
    5 hour 20 minutes
    43.97 meter 131gram
    Print Speed 9.0mm^3 per second
  3. #3
    Jul 2014
    depends entirely on your settings and what resuklts you want to get
    Using flashprint at 0.3mm layer height and 70mm/s 15% infill and 3 perimeters and layers - it clocks in at 5.47 hours and 133gms
    How smooth do you want it and do you own any files and sanding blocks :-)
    A faster, lower resolution print and 10 minutes judicious sanding, can save you many hours of printing at higher resolutions
    0.2mm layer = 7hours and 51 minutes
    so logically 0.1mm = around 16 hours.
    0.16mm layer height gives you around 9 hours. zip file of the .x3g attached.
    The mistake most people make is using the wrong infill and way way too much of it.
    15% TRIANGLE infill not only gives you the best all round strength to material ratio, on a model this size it's also pretty dense.
    Learn what settings do what and never ever use a Stock 'normal, fast, quality' style setting for anything :-)
    Always know what you used and why.
