Results 1 to 5 of 5
Thread: Anet ET4 Circles becomes oval
09-17-2019, 03:05 AM #1
Just got my Anet ET4 and my first two testprints where simple circle objects.
I noticed my circles are coming out slightly oval.
All my axes moves around smooth and freely when manually pushing them around.
Any idea what to check next?
I used a Simplify3D profile for Anet A8, since Simplify haven't listed the ET4 yet.
09-24-2019, 11:19 AM #2
you probably need to change the steps in the startup script. I had to do this for my ctc.
G28 ; home all axes
M92 X80 Y79
G1 X0 Y0 Z0.1 F3000 ; get ready to prime
G92 E0 ; reset extrusion distance
G1 X100 E20 F600 ; prime nozzle
You shoul;d be able to adjust or change it in your firmware - I can't do that with mine. But it's actually much easier to play around with settings in simplify3d startup script.
It could also by a loose belt.
Also it's an ender 3 clone - so, you know, expect problems.
Should have got the anet a8 plus instead.
09-24-2019, 12:38 PM #3
09-24-2019, 01:04 PM #4
Ah well - that's easier than buggering around with the firmware :-)
09-24-2019, 01:49 PM #5
