  1. #1
    Super Affordable Laser SLA 3d Printer!
    SolidMaker is the First Laser SLA 3D Printer Under $500: The structure optimization making high-quality SLA 3D printer downright affordable.
    Enjoy better printing quality & speed with SolidMaker, from only $399. Check more info here👉:http://bit.ly/30bCHH6
    SolidMaker:
    ①Top-notch Printing Quality: With 0.003/0.01mm XYZ accuracy, SolidMaker can eke out astonishing high-resolution 3D prints.
    ②Bigger And More Complex Prints: Print volumes up to 120x120x150mm, it?s ideal for both minis and larger items!
    ③Printing Speed Up to 320mm/s: Stunning creations can be made just in a jiffy.
    ④100μm Laser Spot Size: Smaller spot size to capture the finest details of your creations.
    about SLA:
    SLA printers consistently produce higher-resolution objects and are more accurate than FDM printers. Because the resolution is primarily determined by the optical spot size either of the laser or the projector ? and that is really small. ✌️This way, the surface finish is much smoother. SLA prints show details an FDM printer could never produce.
    ⭐ Sign up for the launch invitation and get the super early bird price now 👉:http://bit.ly/30bCHH6
    You can contact us on facebook Page:https://www.facebook.com/pg/solidmak...=page_internal
  2. #2
    Technician
    Dec 2018
    This 3D printer is very cheap in price with good features in it. Only the thing left is to check and use it for reviews.
  3. #3
    Jul 2014
    Well if you want one testing and reviewing - let me know :-)
  4. #4
    Technician
    Dec 2018
    Well If you can do that it will help me a lot.
  5. #5
    Thanks for letting us know about this laser printer run 3 unblocked
