02-25-2021, 07:57 PM #1
- Jul 2020
- 7
Odd Artifacts on first few layers of ABS vase mode print
Hello All,
I've been working on optimizing an ABS profile in Cura 4.8.0 for printing a small test part (a miniature studded vase in this case), but I am running into issues with the outside surface quality of the first few layers.
The part is printed in vase mode (spiralize outer contour) with the following basic settings:
- Printer: Airwolf3D AXIOM Dual Direct Drive
- Nozzle Size: 0.5 mm
- Layer Height: 0.25 mm
- Line Width: 0.5 mm
- Top/Bottom Thickness: 1.2 mm
- Print Temperature: 250 C
- Bed Temperature: 130 C
- Print Speed: 80 mm/s
- Outer wall Speed: 60 mm/s
- Top/Bottom Speed: 40 mm/s
It seems that the wall layers that correspond with the Bottom thickness have the worst quality (see attached picture). Everything above it seems to print really nicely.
What I have tried so far:
1. Adding a brim (thinking the heated bed might be overheating it) - no change
2. Reducing the print temperature thinking it was just overheating - no noticeable difference
2. Slowing down the outer wall speed (first from 60 mm/s to 40, and then all the way down to 15 mm/s) - no noticeable change in quality.
It seems that the presence of the bottom layers is doing "something" but I'm stumped. Any ideas?
Thanks!
Jason OLast edited by Jdo300; 02-26-2021 at 10:06 PM.
What's wrong with this prting?
04-14-2024, 05:15 PM in General 3D Printing Discussion
