Results 1 to 8 of 8
  1. #1
    Best program for designing a PC case?
    I was wondering if there where any programs out there which where good for designing PC cases?
    I've gotten as far as I can with tinkercad but now im at the stage where i've got to align the case to ATX power supply fittings and motherboard standoff/rear IO panel/PCI slots... and it's tough. I was wondering if there was anything out there which had templates or something which makes the process easier?
    Also if there's a quick way to enter drill/bolt holes & fittings, that'd be useful?
    If not can someone point me in the direction of a place which might have a EATX motherboard tray template which I could buy/download please?
  2. #2
    Jul 2014
    quite a lot of pc cases on www.thingiverse.com
    can't help on the cad as I only use openscad.
  3. #3
    thanks a lot i try that its so cool
  4. #4
    Quote Originally Posted by sam.pear View Post
    thanks a lot i try that its so cool 192.168.10.1 192.168.1.1 10.0.0.0.1
    I want to try it
  5. #5
    I guess every soft has its own features
  6. #6
    Student
    Aug 2017
    Location
    Bold Springs, Georgia
    Any of the high end software, Solid Works, Solid Edge, inventor, etc. If you can afford..
  7. #7
    i will definitely try this... thank you
  8. #8
    Jul 2014
    my best homemade 'pc case' is a piece of plywood. With hole drilled to mount the motherboard and a power supply attached with a bracket.
    Super cheap, really compact and with amazing airflow !
    In fact I even added network switch and turned it into a tiny dedicated server for my laser cutter :-)
    All in the space of a sheet of A4 and about 4 inches high.
