Flash Forge Guider
  1. #1
    Flashforge Adventurer 3 MAC Address
    Hello wise people of the internet,
    I'm hoping someone out there is running a Flashforge Adventurer 3 and can help me answer a question regarding the network side of the printer.
    Do you experience the MAC address changing itself upon each reboot when connecting to via WiFi? Just to be clear, the cable connection is working fine.
    This presents a problem as the IP address changes because the mac address changes. Currently I have a lan scanning program that tells me the IP, which is fine and it works. However I am more curious than anything.
    I have contacted Flashforge support and they seam perplexed at this idea.
    Kind regards,
    Josh
  2. #2
    Josh,
    My A3 printer does the same thing. I can't reserve an IP address for the printer, which means I can't DVR its IP camera. MAC addresses should never change. Let me know if you figure out how to fix it.
  3. #3
    Hi Nerd4Mario,
    I found it was an error in the firmware of the printer. I contacted FlashForge support and they supplied me with a firmware update. I believe it will be included in a future update. If you contact them directly and explain the problem, they will respond back with a custom firmware update.
    So far my A3 hasnt changed MAC address since.
    Good luck
    Josh
  4. #4
    Thank you!
