Results 1 to 8 of 8
  1. #1
    Want to add smart display to this board, is it possible?
    This is a Brainwave Pro from my Openbeam Kossel Pro. These pins are empty on the board. Do these pins look like a display can be added?
  2. #2
    Jul 2014
    I can't see the connector most boards have for the smart screens - is that the underside of the board ?
  3. #3
    Engineer-in-Training
    Jul 2016
    Location
    South Florida, USA
    Add AutoWiz on Facebook
    Perhaps instead of Mike, Mathew, and Terence you should spend your monies on a product from MakerBase, a slightly bigger name in the world of 3d printing. Like the MKS gen L for example. It is a cheap mainboard. And natively works with all MKS touchscreens and also MKS external mosfets for off-board heated bed power.
  4. #4
    That is the underside of the board. There are labeled pins but I didn't recognize anything that would work with an off the shelf display.
  5. #5
    Jul 2014
    what's the top look like ?
  6. #6
    Engineer Roberts_Clif's Avatar
    Jun 2017
    Location
    Washington State, USA
    It appears that this was a Kick-Starter project from 2013
    Specifications:
    Atmel AT90USB1286 microcontroller
    4-axis, 4 endstop control
    Extra thermistor output
    4 x 2.5A TI DRV8825 stepper driver ICs (with hot-plug damage hardened)
    1-1/32 microstepping configurable
    250W heated-build platform driver
    Onboard replaceable fuse
    12-45VCD input
  7. #7
    Jul 2014
    well the connector top - middle, looks like the right socket for a smart lcd to me.
    It's certainly the same type that mine's plugged into.
  8. #8
    U can add it Its Good
