Flash Forge Adventurer 3
  1. #1
    How much would it cost to print a figure?
    Hey, I am new here!
    I have a couple of questions.
    How much would it cost to get a 3d printer which could print this figure in a good quality?
    And how much approximately would it cost to print the figure 10 cm long or 20 cm long if I bought a printer?
    https://ae01.alicdn.com/kf/HTB10TvKR...pg_640x640.jpg
  2. #2
    Jul 2014
    depending on the printer the material to print could be anything from a 50 cents on up to a few dollars.
    for the 20cm print start thibnking around $4-500 and a resin based machine.
    For the 10 cm, you'd still be better off with resin - from aquality point of view, so similiar price :-)
    If you want to stick with fdm - then a dual nozzle system for soluble supports would be a good idea.
  3. #3
    Engineer-in-Training
    Aug 2015
    For a resin print, a 10cm print could cost between a $1 to $10, depending on how well you hollowed it out well before printing, how thin the walls were, and how much support you used.
    A hollow 20cm print with the same wall thickness would cost about 4 times as much as the 10cm print.
  4. #4
    3D printing will not cost you more. It depends on what you are printing and which material you are using to print.
  5. #5
    The cost will depend on which type of 3D printer you want, what is your requirements and what type of material you want to use.
