Thread: Ender 3 Build Space usage
12-24-2018, 06:46 PM #1
- Dec 2018
Hello there,
I?m new to 3D printing but able to resolve most problems myself.
Recently I encountered a problem with a very large piece that almost uses the whole build surface. While printing with a brim I noticed that the round piece got cut of at the edges of the build surface. The printer refused to print a curve, just ignored the G-Code and printed a straight line following the shape of the build surface.
Cura didn?t show any of this and there was a good min 1.5 cm headroom to all edges.
Is there a set value of boundaries in the Marlin firmware?
Didn?t find a solution on google or the search function in this forum.
Any help is appreciated.
12-24-2018, 09:06 PM #2
Yes there are boundaries.
In Marlin, and in Cura. Both should be set for the build area for your 3D Printer.
12-25-2018, 08:21 AM #3
- Dec 2018
Found the section in Marlin (vanilla 1.1.9) under config.h
Strangely it was set at 220 instead of the 235 of the printer tough Ender 3 was configurated.
235 troughs out an error with my BLTouch being out of the probe range, 230 works just fine.
Thank you now cura and the printer are uniform and 5 mm lost I can count as a safety range.
12-26-2018, 01:14 PM #4
- Nov 2018
- 28
I avoid filling the entire build plate if possible. To easy for things to go wrong IMO
Yesterday, 01:26 PM in General 3D Printing Discussion
