Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
  1. #21
    Engineer Roberts_Clif's Avatar
    Jun 2017
    Location
    Washington State, USA
    Quote Originally Posted by Madda View Post
    Do i have underextrusion?
    Can you tell me how to install your cura profile there are ".ini" files and cura only likes ".Curaprofile".
    Cura uses both the older versions use .ini the newer versions use .Curaprofile
    You can look at what I have and adjust what you need and create your own specific profiles.
    The number is for layer height.
    Attached Files Attached Files
  2. #22
    Hey madda - i found this to be very helpfull getting some knowledge about the settings.
    profile for ender 3:
    http://www.emcu.eu/configure-ultimaker-cura-software-for-use-the-creality-3d-printer-model-ender-3/
    Turtorial Cura:
    https://all3dp.com/1/cura-tutorial-s...licer-cura-3d/
  3. #23
    Student
    Dec 2018
    Location
    Sweden
    Quote Originally Posted by OwiHH View Post
    Turtorial Cura:
    Thank you for the tips. There are a lot of profiles out there and i'm beginning to believe that i have hardware problem or something.
  4. #24
    Student
    Dec 2018
    Location
    Sweden
    Quote Originally Posted by Roberts_Clif View Post
    Have you can look at what I have and adjust what you need and create your own specific profiles.
    Alright could you give me a recommendation to make the print stick to the glass bed. It wont stay put!
  5. #25
    Jun 2017
    Location
    Have never printed on Glass, though believe it would be similar as any other surface.
    They say to use Elmer's glue sticks for best adhesion. Can you post a picture of what your failed model starts looks like.
  6. #26
    Student
    Dec 2018
    Location
    Sweden
    Didn't get very far this time. Also shouldn't it be a solid layer?
    looks like the tread won't connect with each other.
  7. #27
    Also heat up the glass up to 65 manual befor starting printing first layers. After it you can reduce to 55 - 60. Worked good for me.
    Use "Brim" layer option for first layer also helps for small parts sticking to the bed.
  8. #28
    Student
    Dec 2018
    Location
    Sweden
    -I put something behind the spring tightening it.
    -Then i raised the bed a bit after watching this guys first layer that resembeld mine https://www.youtube.com/watch?v=AaF28dnDgKA (Need to raise it just a bit more) and
    tried "Hictop Blue - .20.curaprofile" that i got from you.
    -It stuck onto the bed the entire print so it finished. But i could hear the nozzle going through and breaking some of the infill when it crossed.
    It's a massive improvement compared to the others. But it's not flat and is rough wrinkles on the side.
    The entire boat is very roughly made if that makes sense.
    Is it under extrution?
  9. #29
    Jun 2017
    Location
    What are you using for Nozzle and Bed temperature.
    What print speed percent is Cura set to.
    What you are telling me is that you may have too low nozzle temp or the popping sound could be moisture in the filament.
  10. #30
    Student
    Dec 2018
    Location
    Sweden
    Default printing temp 205C
    printing temp 198C
    printing temp Initial layer 198C
    Initial printing temp 188C
    Final printing temp 183C
    Default build printing temp 70C
    build printing temp 50C
    build printing temp Initial layer 50C
    (I cant find it, but i found these)
    Print speed 60mm/s
    Initial layer print speed 10mm/s
    Overhanging wall speed 100%
    The popping sound could be moisture in the filament
    Shit...Do i have to replace it?
Tags for this Thread
