Results 11 to 12 of 12
11-26-2018, 08:24 PM #11
- 887
It's not so much a specific feature, but a combination of them. In this case, after reducing the triangle count (IMPORTANT!), I selected W for wireframe view, then used the select tool to select all the triangles surrounding the depressed lettering. After consulting with a mental health professional, it was decided the best approach was to delete the selected triangles. This removed the support structure for the depressed triangles, causing them to fail the Analysis/Inspector. Automatic repair removed the letters and closed over the resultant gap. It's important to avoid surrounding more than one letter at a time, as it will result in a repair that creates a depressed mostly flat area, not longer planar. There may be some remnants of my failure in that aspect, although I performed the delete and repair over those valleys with great success.
11-27-2018, 06:21 AM #12
Thank You again fred_dot_u
For you specific tour of the steps taken to remove lettering, I downloaded the newest MeshMixer installer it over my older version.
Now will search for tutorials to start learning how to make MeshMixer work for me...
