Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Engineer-in-Training
    Jul 2016
    Location
    South Florida, USA
    Add AutoWiz on Facebook
    I used to play with the Arduino controllers long before 3d printing came around. For car functions. Like I used an Arduino nano and a few 5v relays to make an autolamp module for my car. And I even used a mega to make a full bcm(body control module) for my old Honda. So I was already familiar with the Arduino environment and writing sketches and when I saw marlin I just identified with it. There are newer versions of it that you could use for your old ctc machine. I actually like marlin. I think it is really cool how everything is there and you just uncomment things to activate them or comment them to de activate them. But you never really have to write anything. maybe just change values.
  2. #12
    Jul 2014
    yeah 0.9 - and so far utterly failed to update it or change settings.
    I do have a spare mks gen 1.4, but unless I can figure out some way to plug 2 z-motors into it - it's not much use for the ctc.
    so if you slice a model with s3d and stick it on a sd card it works ?
    but not if you use direct usb ? (which you're not going to do much)
    That doesn't make any sense - but it sounds like your startup gcode isn't configured properly.
    You're using the same boards and extruders, bed levlellers etc, on all your machines aren't you ?
  3. #13
    Jul 2016
    Location
    South Florida, USA
    Quote Originally Posted by curious aardvark View Post
    There are actually 3 different ways for you to achieve this. First if you only have one extruder then you have an extra unassigned stepper driver that can be assigned to z2. If you have 2 extruders and no unused stepper driver sockets on the board then you can wire the 2 z steppers in parallel with the one driver and they will both work together. This can only work because the z axis sees such light load that the stepper can handle driving 2 motors. And finally you can add an extra stepper driver add on board. These are universal and can pretty much be added to any 3d printer mainboard and then configured in marlin. I think marlin is up to 1.1.9, now.
  4. #14
    Jul 2014
    looking around the net - it looks like the firmware can be updated.
    I'm pretty sure I've tried all the things I've seen that supposedly work.
    Who knows.
    not an old ctc machine - this years latest model - why they used such an out of date and utterly useless firmware is beyond me.
    It's not like decent firmware would have cost ctc any money.
