Results 1 to 10 of 13
10-30-2018, 02:36 PM #1
- Oct 2018
- South Africa
- 7
Problems updating Tevo Flash firmware
Hello,
I am new to 3d printing, and recently purchased a Tevo Flash. Everything was fine till after several weeks of use I tried to update the firmware. After flashing though, the LCD (while turning on) remains blank. Being my first try, it is entirely possible I didn't flash the correct marlin or something, but after many different tries I downloaded the original Tevo Flash firmware, and flashed that. Unfortunately the LCD is still not functioning.
When connecting the printer via USB and opening Cura, I can preheat the nozzle just fine, the tempteture reading is stuck on 111 degrees though, and the bed temp is not displayed. I've tried lots of fixes, from trying to change the LCD contrast to enabling different LCDs in the configuration.h file in Arduino. Any help with this issue would be greatly appreciated.
10-30-2018, 03:49 PM #2
Post a link to your Marlin Firmware.
or try this
https://github.com/JimBrown/MarlinTa...onfiguration.h
10-30-2018, 06:29 PM #3
and learn the lesson: if it works - don't bugger about with it :-)
One thing to check. Make sure the configuration.h file actually has your screen selected.
Sounds like maybe it's choosing the wrong screen.Last edited by curious aardvark; 10-30-2018 at 07:28 PM.
10-31-2018, 02:13 AM #4
- Oct 2018
- South Africa
- 7
Haha yes, lesson learnt. And I'm not sure if there is a different way. But what I did was go into the configuration.h to the LCD controller section and enable the display most similar to mine. I have the MKS Mini. Is that the correct way to do that?
10-31-2018, 02:14 AM #5
- Oct 2018
- South Africa
- 7
Thank you, I'll try that one. Unfortunately I don't have enough posts to send links yet.
10-31-2018, 02:27 AM #6
- Oct 2018
- South Africa
- 7
You were right!! I tried another config program and managed to find my LCD specifically! The LCD is working now, thank you two for your help! Unfortunately I still have one more problem, the temperatures are still stuck. I'm thinking it is a problem with the hotend thermistor, as when I tighten it it changes from 111 degrees to -14. But what confuses me is that the bed temperature stays at around 108 degrees, which is strange because I never touched it. After replacing the nozzle the temps just jumped there and stayed there.
10-31-2018, 05:28 AM #7
There are two temperatures that you should memorize.
-14 C -- Open Circuit
358 C -- Short Circuit
This is on my 3D Printers anyway. You can test this yourself.
10-31-2018, 06:56 AM #8
- Oct 2018
- South Africa
- 7
Okay yes. So I measured the resistance of the thermistor. Its about 50k ohms at room temperature. But no matter what I do the temp is still displayed at 111 for the hotend and 108 for the bed. Even plugging out the cables going to the hotend makes no difference. Do you think its a problem with the board?
10-31-2018, 07:43 AM #9
Glad we got your screen working again :-)
For some screens you even have to add extra libraries to ide.
how warm is the room ?
could just be measuring ambient temps. (I don't do farenheits)
But sounds more like bad wiring somewhere.
10-31-2018, 07:56 AM #10
- Oct 2018
- South Africa
- 7
Ah sorry, I forgot to mention this is indeed in degrees Celsius. So not room temperature. And could be. Like I mentioned I might have damaged the hotend thermistor by accident, but I haven't touched the bed. Are the two linked in any way? If not, what could cause both temperatures to be stuck on a high temp? Just for information's sake, both the hotend and the bed start heating properly, they naturally just shut down because of the safety features not detecting a temperature change. The steppers are also functioning just fine.
What's wrong with this prting?
04-14-2024, 05:15 PM in General 3D Printing Discussion
