Flash Forge Adventurer 3
  1. #1
    Unhappy .stl won't slice properly
    Not sure if this is where to put this, (just joined), but I need the answer urgently for school. I made a model in blender that I exported as an .stl file. Everything seemed to be going fine, until I sliced it. It didn't do anything; no error message, except the popup that it was successfully sliced. (Same result in both Slic3r and Printrun). Everything worked but there was nothing there anymore; if I did it in .obj, it was successfully previewed, but the same result when slicing. No error message, successfully sliced; nothing there. Please answer quickly, this is due in two days aaaah ;-; !!
  2. #2
    Technologist
    Jun 2014
    consider to run the model through an online checker program, or use Meshmixer as a stand-alone with the Analyze feature.
    You could also attach the file here for others to examine in a similar manner.
  3. #3
    The online checker problem has the same problem as the slicers, it doesn't detect any problems, no error msgs, but there's nothing there.
  4. #4
    resolved! after 2 freaking hours of troubleshooting, thx anyway
  5. #5
    Technologist
    Jun 2014
    what was the final solution?
  6. #6
    The online checker issue has indistinguishable issue from the slicers, it doesn't distinguish any issues, no mistake messages, however there's nothing there...
    http://pc-express.com.au/
  7. #7
    Jul 2014
    was it an ascii versus bin stl file type issue ?
    I've had that. Think you need bin for most slicers.
