04-04-2018, 11:30 AM #1
- Apr 2018
Resetting Cura to default settings
I'm being forced to use Cura for several prints that PronterFace can't do. I've made a few changes to the settings and I want to go back to the default settings for Cura. I'm pretty sure I remember seeing an option to do that, but I can't find it. I've been going down every menu option and reading every line, but I can't find it. And of course, the Cura documentation doesn't seem to want to help me with this either. I've even tried uninstalling Cura and re-installing it. That doesn't get me back to the default settings.
Does anybody know off hand how I can get Cura back to the default settings?
04-04-2018, 04:35 PM #2
Hello;
Cura has hidden directories
To change the folder options in windows 7 let's say
Select root directory
Click Organize
Click folder and search options
Click View tab check show hidden files, folders or drives Radio button
Uncheck Hide protected operating system files (Recommended)
C:\Users\"Your Login ID"\AppData\Roaming\cura
After you uninstall Cura delete this Cura directory and all content to restore Cura defaults
Then
Click Organize
Click View tab check don't show hidden files, folders or drives Radio button
Check Hide protected operating system files (Recommended)
to restore default system folder setupsLast edited by Roberts_Clif; 04-04-2018 at 04:44 PM.
04-06-2018, 03:40 AM #3
- Apr 2018
Do not understand about Cura but also good luck, soon find a good answer
