  1. #1
    How to control the print direction of each layer individually?
    Is it possible to, for example, make each layer of a solid cube offset by a certain angle? Or maybe alternate layers between concentric squares and normal lines.
  2. #2
    Nevermind, I guess the beta version of Cura for sigma bcn doesn't let you change the infill pattern. Is there a way to modify the gcode somehow as a workaround?
  3. #3
    Technologist
    Jul 2017
    I'm not too sure what you mean by changing infill direction. From what I'm aware the rectilinear/grid infills alternate direction to give you a cross hatch sort of effect. Secondly, "modifying" the Gcode itself for a different infill would be a living nightmare. You'd need to program each and every move it makes. I doubt you can't change infill settings, but even if that's the case just use a slicer where you can.
  4. #4
    Jul 2014
    simplify 3d lets you do that no problem.
  5. #5
    3DPrintBoardPro Member car3less's Avatar
    Oct 2014
    Location
    Bucuresti
    Follow car3less On Twitter Add car3less on Facebook Add car3less on Shapeways
    Sounds also like Grasshopper. There is a plugin that lets you modify the GCode - Silkworm.
    Printare 3D Bucuresti
    Any sufficiently advanced technology is indistinguishable from magic. Arthur C. Clarke
