Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    List of some of the most popular D3 modeling software are Sketchup, LibreCAD, SelfCAD, AutoCAD
  2. #12
    Jul 2014
    the old cura was quite good. But then they completely redesigned it and since then it's been really horrible.
    The last user friendly version was: 15.04.6
    here's a list of al releases: https://ultimaker.com/en/products/ul...-software/list
  3. #13
    I'm using Solidworks. That's what I advise..
  4. #14
    You can look my 3d print model the website below.
    https://www.3d2v.com/n.design
  5. #15
    Technician
    Dec 2018
    I will suggest you some of these best 3D modeling softwares - LibreCAD, TinkerCAD, Blender and SketchUp etc.
  6. #16
    Engineer ralphzoontjens's Avatar
    Nov 2013
    Location
    Tilburg, the Netherlands
    Follow ralphzoontjens On Twitter Add ralphzoontjens on Facebook Add ralphzoontjens on Shapeways Add ralphzoontjens on Thingiverse
    If you can afford a license, Solidworks. The next best thing is Rhinoceros, it is great with meshes as well.
    For a nice free and quick solution use Sculptris.
    I use Blender to boolean away shapes, say create a flat bottom. That is about what I know in Blender, steep learning curve indeed.
  7. #17
    Technician
    Dec 2018
    @Ralphzoontjens, I agree with you, Sculptris is also a good option and the best thing is that it is free. Most of the educational institutes use Sculptris for educational and enrichment purposes.
  8. #18
    You should have a look at www.rocket3f.com/ (just add dotts)
  9. #19
    Jul 2014
    Added the dots :-)
    Looks interesting, and the basic version is Free !
    Which as everyone knows, is my favourite cost of anything :-)
    I need to make 3d faces on spheres, and doing it on openscad is a real pita. So let's see if i can use this rocket thing instead :-)
    well first snag - it doesn't save or export as .stl
    About the only thing I can see that openscad will import is .dxf
    have to try that instead.
  10. #20
    Quote Originally Posted by curious aardvark View Post
    Added the dots :-)
    You could export it to obj and then open it in 3D Builder
    www(DOT)microsoft(DOT)com/en-us/p/3d-builder/9wzdncrfj3t6?activetab=pivotverviewtab
    Her is a little about it: www(DOT)windowscentral(DOT)com/how-use-3d-builder-windows-10
    Its easy to use and you can export to stl from there, and its free.
