Flash Forge Inventor Series
  1. #1
    Question HELP: Weird Temp Issues
    All of a sudden when I try and start a print, after 10 seconds after starting the first layer the extruder temp flashes a negative number quick than goes undefined, BUT it will preheat at those same temps for a long time without erroring...
    my printer had a melzi 2.0 red board in it
    video: https://photos.app.goo.gl/wKOcFyhE5CVSAzlM2
  2. #2
    Engineer-in-Training Roberts_Clif's Avatar
    Jun 2017
    Location
    Washington State, USA
    It sound like your thermister is shorting out on the Heater Block. The thermister should be pushed all the way into the temp hole, including the Teflon thermal tubing.
    Each Teflon tubing should be placed one on both sides if the retainer screw with washer, forming a Y around the retainer screw. This keeps the thermister in place without shorting out.
  3. #3
    Quote Originally Posted by Roberts_Clif View Post
    You're right, it was shorting out! I got a weird one that is kind of cemented in place, will have to replace the block. Thank you!
  4. #4
    thanks guys a lot! i've been having the same problem and i am not sure what's the solution. i haven't yet tried and didn't sorted it out, but Roberts i will try it out and see if it works for me. thanks tracetheory for updating as well. if something goes wrong may i come back here asking some questions? thanks a lot for everything.
  5. #5
    Jun 2017
    Location
    Hope it Works!!!
