09-20-2017, 02:51 AM #1
- Sep 2017
Can a 3D scanner capture minute detail of a watch case? Can 3D printer render it ?
Can a typical 3D scanner capture the minute details of a watch case and can the 3d silver printer render it precisely enough to ensure that the mechanism and glass will fit properly?? Does 3D printed silver have the smooth shiny finish desirable for a ring or watch? Would this be extremely expensive?
09-20-2017, 04:24 AM #2
I'll answer the last question first.
Yes it would be extremely expensive.
All 3d printed metals generally need to be finished and polished - as do all cast metals.
I have a seen a machine that can both print and finish a part in one go. Costs £750,000 and is as big as a medium sized van, while only having a working volume of a 6 inch cube.
No such thing as a typical 3d scanner. The desktop scanners you can get would not capture sufficient detail and the commercial ones start around the $20,000 mark and probably would.
Any way you look at it - it will be expensive. At the moment in the 3d printing world, it is always faster and simpler to design something from scratch. When duplicating an object, it's easier and quicker to simply use digital calipers to measure and design from the measurements.
What most jewellers do is to design the piece, print it in a castable material and use conventional means to cast the piece.
09-20-2017, 03:13 PM #3
- Oakland, CA
- 935
What's this "3D silver printer" of which you speak? Is this a machine that prints objects directly in silver? Who makes it?
Which 3d printer for small...
