03-29-2017, 03:02 PM #1
- Jan 2016
- 326
Turn LEDs on or off in S3D software?
I have PowerSpec 3D Pro 2 (Flashforge Creator Pro clone) printer and Simpify 3D 3.1.1 software. In the FFF Settings/Scripts window, I couldn't find the code to turn LEDs on/off or change colors of LEDs. How can I add the code for LEDs to the scripts?
03-30-2017, 06:00 AM #2
no idea I just set them up from the printers control panel.
03-30-2017, 02:51 PM #3
- Jan 2016
- 326
When I had the PowerSpec 3D Ultra (Flashforge Dreamer clone) printer last year, there is code for changing the color of the LEDs or turn them off. The code is missing from scripts for Flashforge Creator Pro that I use for my PowerSpec 3D Pro printer. Also, my printer doesn't use GPX files. It uses GCODE files.
Code:; **** Replicator 1 dual start.gcode **** M73 P0 ; Enable build progress G162 X Y F3000 ; Home XY maximum G161 Z F1200 ; Home Z minimum G92 Z-5 ; Set Z to -5 G1 Z0 ; Move Z to 0 G161 Z F100 ; Home Z slowly M132 X Y Z A B ; Recall home offsets M135 T0 ; Load right extruder offsets G1 X-120 Y-70 Z30 F9000 ; Move to wait position off table G130 X20 Y20 Z20 A20 B20 ; Lower stepper Vrefs while heating M126 S[fan_speed_pwm] ; Set fan speed M140 S[bed0_temperature] T0 ; Heat buildplate M134 T0 ; Stabilize bed temperature M104 S[extruder1_temperature] T1 ; Heat left extruder M133 T1 ; Stabilize left extruder temperature G130 X127 Y127 Z40 A127 B127 ; Default stepper Vrefs G92 A0 B0 ; Zero extruders M135 T1 ; Load left extruder offsets G1 X-100 Y-68 F9000 ; Move to front left corner of bed G1 Z0.3 F6000 ; Move down to purge G1 X90 Y-68 E24 F2000 ; Extrude a line of filament across the front edge of the bed G1 X100 Y-68 F180 ; Wait for ooze G1 X110 Y-68 F5000 ; Fast wipe G1 Z1 F100 ; Lift G92 A0 B0 ; Zero extruders M73 P1 ;@body (notify GPX body has started) ; **** end of start.gcode ****
04-01-2017, 11:32 AM #4
- Jan 2016
- 326
My PowerSpec 3D Pro printer uses Sailfish firmware. I downloaded the manual for Sailfish and found out that I can't turn the LEDs on or off at the control panel (It's not in the Pause menu).
04-06-2017, 05:38 AM #5
so you want to start with them on and switch them off halfway trhough a print ?
What i was referring to is the led controls under settings. You can set colours for specific tasks, or whether they are used at all. Nothing to do with the pause menu.
04-06-2017, 07:42 PM #6
- Jan 2016
- 326
Is it possible to put a switch on the wires going to the LEDs? I want to turn off the LEDs before going to bed.
04-12-2017, 10:16 PM #7
- Feb 2017
thanks you for share!
