Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Student
    Aug 2016
    Location
    Edmonton AB, Canada
    Rounded Overhang
    Hi everyone, new to the forums here, and I have a problem that i'm hoping someone might be able to help with.
    I'm trying to print the popular Baby Groot model found here.
    http://www.thingiverse.com/thing:2014307/#made
    when I try and print the head the rounded overhang of his chin prints are horrible.
    (black is with supports - Grey without)
    I've tried all sorts of things, changing the infill, adding supports, adding denser supports etc, all with the same results. Any time I print say a sphere, the bottom half prints like garbage and the top prints mint.
    Anybody know what I'm doing wrong?
    I'm printing on a Dreammaker Overlord Pro with hatchbox PLA
    Thanks everyone hope someone knows what my issue is.
  2. #2
    Technologist
    Oct 2016
    You could try lowering layer height to 0.1 mm or even lower if possible. Also if you print with more than one perimeter, print outer perimeter last, it should produce better results.
    If you use Simplify3D, here's some tips to get better supports: https://www.youtube.com/watch?v=piwKAOOaPKc. Personally I found that lowering the support resolution works better.
  3. #3
    Student
    Aug 2016
    Location
    Edmonton AB, Canada
    Quote Originally Posted by spegelius View Post
    Thanks for the reply. I tried lowering the resolution to .1 and used 3 layer shell, made everythign worse. Most of the filament just ended up a stringy mess.
    I'm not using supports preferably, as I shouldnt have to, this print doesnt require supports, people use supports and infill like a crutch. I did however make sure infill was high enough to print the top of the head, definiitely needs a dense net for that.
    When I printed the one with support, the supports werent even touching the model like the whole time, it was a complete waste of filament. got not time for supports.
  4. #4
    Technologist
    Oct 2016
    Quote Originally Posted by VonKlutch View Post
    Is the whole print a stringy mess? If so, sounds weird because lowering the layer height should improve quality. Then again not every printer and their settings behave similarly...
    Stringy mess might be result of lower layer height throwing the feed rate off; half the material = less force needed to push filament and with extruders that normally slip, might cause too much material to be output. So lowering the extrusion multiplier could help.
    I've bee meaning to print this model too, I'll see how Prusa MK2 handles that part.
  5. #5
    Engineer ralphzoontjens's Avatar
    Nov 2013
    Location
    Tilburg, the Netherlands
    Follow ralphzoontjens On Twitter Add ralphzoontjens on Facebook Add ralphzoontjens on Shapeways Add ralphzoontjens on Thingiverse
    It doesn't work for all filaments, but setting the temperature at the lower end of the permitted range, say 195C for PLA, with the right amount of cooling, will improve these parts as well.
    But mostly this is a matter of good support building. The best supports are peelable structures such as zigzag supports in Cura. Also Craftware has great support options: https://craftunique.com/craftware
    Let me know how it works out.
  6. #6
    Engineer Marm's Avatar
    Sep 2014
    Add Marm on Thingiverse
    I'm going to grab the low hanging fruit here and say try supports. Just because you shouldn't have to use them doesn't mean you don't.
    And saying People use supports like a crutch seems quite elitist to me. There are many different ways to skin a cat, and if it works, it works. If this was a production/commercial setting, getting the initial run to work using supports, management wouldn't care, as you had a working product. If you then refined the process to not use supports, they would be even happier as you are now saving them money. But wasting time delaying production on the perfectly optimized setup never goes over well. And since you're obviously not doing this for a commercial run, copyright laws and all (and if you were, you would be using injection molding, not 3d printing, given the size of a run you would need to turn a profit), I don't see what the hangup is over supports. Yes, they're a pain to clean up sometimes, and I try to avoid using them whenever I can, but If I need supports, I use them. One of my commercial products I do print I have to use supports, and I do, and I spend the 20 minutes cleaning up the piece.
  7. #7
    Staff Engineer printbus's Avatar
    May 2014
    Location
    Highlands Ranch, Colorado USA
    Add printbus on Thingiverse
    I read through the comments on the Thingiverse item, and sort of laughed when the originator said supports shouldn't be required.
    You have to think about how these FDM printers work - a new layer is "squished" onto the layer underneath it. When you get into an overhang, well, there's less and less to squish onto. Simple as that. This is EXACTLY what is happening in your grey print without supports. Up to a 45 degree slope should be easy peasy, but this model requires far more severe of an angle than that. Have you tested your printer and slicer settings on a calibration model that tells you what your setup can do as far as overhangs?
    I don't know what kind of pixie dust the Thingiverse originator has to use with his machine, but if I dared to attempt the model it'd have to be with a lot of supports, a just barely hot enough temp and some pretty extensive cooling airflow, hoping to freeze the filament before it had a chance to droop, whether that droop was onto almost free air or onto the support structure.
  8. #8
    Student
    Aug 2016
    Location
    Edmonton AB, Canada
    Quote Originally Posted by Marm View Post
    I did use supports in the original picture. The black print is the print with supports. And I mean that people use these settings a little too much from what I've seen. I watched a video by the 3d printing nerd and he started talking about not printing with infill and stuff and relying on your printers ability to print overhang, kinda changed how i print, and I've had success with it thus far, this however is definitely a different story, like I said before, I did use supports, but it didnt help.
    Yes I have run an overhang test. I was able to get to like 60 degrees before it wasnt acceptable. Its not the prettiest, but its acceptable. not like what my print looks like.
    and for some mysticism
    https://youtu.be/NnujowpIBqM?t=32s
  9. #9
    Sep 2014
    Fair nuff! And I do appreciate the intelligent, non-combative reply to what be considered an aggressive comment. I totally missed the picture captions too, my bad! Soooo..... ummmm... try thicker supports? .
    I have gotten a kick out of watching his channel from time to time. Smart dude it seems.
  10. #10
    Technologist
    Oct 2016
    I printed the head and as expected, the result isn't perfect, but good enough for me. Should be fine with bit of post processing.
    Sliced with KISSlicer, 0.1 mm layer, 0.45 mm extrusion width, 2 perimeters, supports enabled (support threshold 71 degrees). Printed on Prusa i3 MK2. Material is white PLA (Cel Robox), @205 celsius, with part cooling on. I haven't run any calibration for this material, as I normally don't bother.
    Would be interesting to try with another slicers, Simplify3D and Prusa's Slic3r (has 0.05mm quality preset).
    https://dl.dropboxusercontent.com/u/...2010.47.40.jpg
    https://dl.dropboxusercontent.com/u/...2010.47.50.jpg
    https://dl.dropboxusercontent.com/u/...2010.48.00.jpg
    https://dl.dropboxusercontent.com/u/...2010.48.08.jpg
    https://dl.dropboxusercontent.com/u/...2010.49.22.jpg
