Results 11 to 15 of 15
Thread: Severe Delamination Help
02-06-2017, 11:42 AM #11
- Apr 2015
- Northern Ohio
- 198
I never ever fight to get a part released and that seems to be the norm for most that use glass. The Freezer and they fall off without any pressure if that ever becomes an issue.
Ahhhhh the impression... Silly boy. Leaving the front door wide open and the top off is pretty much there with an open system which I use for PLA and PETG. Another fail on your end.
Another swing and a miss. I do use PLA, PETG, HIPS, PVA, and Nylon. I have tried TPE's and TPU's (friend works for a company that makes TPU's and gives me free samples to try and report back) I just don't have a use for them.
Hmmm... A sample size of one... Yourself. While regurgitating without experience is a bad practice listening to others and trying to replicate it on your own gives you a broader view on things instead living in your parents basement relying solely on your own opinions.
Something to think about. I know you've called me a nerd in the past but surely you can grasp this.
"Sample size determination is the act of choosing the number of observations or replicates to include in a statistical sample. The sample size is an important feature of any empirical study in which the goal is to make inferences about a population from a sample."
None here. We leave the political banter to the liberal/progresive mess to talk about.
Great if you like leveling your bed often.
Sorry about your luck there..... Glass in the freezer and it's off in 10 minutes with a stubborn print :-)
I am not being negative. I am offering a rebuttal to your one trick pony. I take issues with you because you have to chime in on everything as the "all knowing" You give advise on engineering material/geometry related topics where you are completely unqualified. How is that helping anyone?
02-06-2017, 01:56 PM #12
My bed right now looks like a mine field, I HAVE to use some layer over the glass. Printbite seems to have such good reviews, I'm game to try it, especially at the price, compared to getting a new bed.
Glue stick has been my goto for years now, but I have to try something different.
02-07-2017, 04:28 PM #13
Sigh............... I've never seen glass break apart... and raise up.......
My glass bed is filled with pot holes. I need to span those gaps. CA's advice seems to be a perfect solution.
You seem to assume that ALL printer's work like yours, that you can easily remove the glass and throw it into a freezer. Even if I had a freezer empty enough (A full household of kids kinda prevents this) to place my print into, the labor of completely disassembling the case of the printer, disassembling the Z axis, unplugging the bed from the board, placing that in a freezer, removing the print, reassembling the Z axis, plugging it back in, reassembling the case, is kind of a pain in the ass.
If you want to be helpful, make sure to read the OP's, and then respond constructively to that. CA offered a very viable, and CHEAP, solution to my problem. Not one of your comments was any help at all.
02-07-2017, 07:53 PM #14
- Apr 2015
- Northern Ohio
- 198
Sorry... You are right. I missed the reference to the specific printer that you were using.
02-07-2017, 09:32 PM #15
And, if you look outside your window, you'll understand part of my problem, I'm a NEO'er too. I really don't have room inside my place to run this thing, but the unheated 3 car garage has become my workshop. Aside from me, finishes and glues, it's the only real thing that's cold sensitive.
If this sheet works, then I'm a happy camper, and I'll start prewarming the enclosure.
What's wrong with this prting?
04-14-2024, 05:15 PM in General 3D Printing Discussion
