Results 1 to 10 of 10
Thread: Bad 3D Benchy
01-23-2017, 03:59 PM #1
- Jan 2017
Bad 3D Benchy
My 3D Benchy test print did not come out great. I have a printrbot simple metal.
Do you have any recommendations on how I can make my prints better? Thank you!
01-24-2017, 01:22 AM #2
- Aug 2015
- 241
Please post a list of the settings settings you used, and what printer,
also don't print in transparent materials, you cant clearly see all the defects
01-24-2017, 08:14 AM #3
As above, please post a link to your slicer setting and that will really help.
However, a few points:
It seems that your Benchy is fairly small and this may affect the quality of the model. (try printing bigger if possible)
Also, your layer height (resolution) seems quite high. I would suggest a layer height of 0.1mm. Or if you want a really detailed model perhaps try 0.05mm layer height.
I can also see your infill lines showing through. Although this is common and probably not something that is very bad, you can fix this by having a thicker wall (try 0.8mm) or asking your slicer to print the wall before the infill.
I hope some of these above points help. With a picture of your settings I might be able to be of more help.
Regards,
3DEX - Great Filament
01-24-2017, 09:54 AM #4
- Jan 2017
Here are some pictures.
I can get screenshots of the slicer settings in a minute.
01-24-2017, 10:16 AM #5
- Jan 2017
Here are the Cura settings.
I am using the Printrbot Simple Metal with an X axis upgrade.
01-24-2017, 12:44 PM #6
- Aug 2015
- 241
your pics of the Cura settings are too small toe read
the other pictures looks like the temp is a bit too high, and the has a lot of ringing,you could adjust the jerk settings so the are slower, and try a lower and slower temp
02-01-2017, 06:12 AM #7
Not entirely sure what you are expecting - but those prints are quite good.
And yep, even i can't read the settings even if I get real close to the monitor :-)
02-01-2017, 11:09 AM #8
- Apr 2015
- Northern Ohio
- 198
02-01-2017, 11:10 AM #9
- Apr 2015
- Northern Ohio
- 198
02-27-2017, 06:57 AM #10
Which 3d printer for small...
03-27-2024, 05:24 PM in General 3D Printing Discussion
