  1. #1
    Turntable scan, flipping object, never aligns
    Hello, first time poster:
    I have a small object 2x3x1 inches. The object is not symmetrical at all. When I do a turntable scan (20 steps - just for kicks) everything looks great. I then flip the object over to get data on the unprocessed underside of the object with an additional scan. Another great scan occurs, but every single time I try to merge the two scans (just pressing the green checkmark) I get a flipped (180 degrees) version of my object superimposed on my original. I would think that there is definitely enough data to align the two no problem, but it just doesn't. I can manually align, but I hate doing that because I feel like it doesn't turn out as well. If I were to just rotate the object, and not flip it, for additional scans, it works as it should.
    I could of sworn I read somebody else having this issue, but I can't remember what their work around was. Any tips?
    Thanks a ton!
    Dr Fill
  2. #2
    Technologist
    Jul 2014
    Location
    UK
    Have you tried manual alignment ?
  3. #3
    Student
    Sep 2020
    Location
    Los Angeles
    Follow Jasink On Twitter
    Quote Originally Posted by DrFill View Post
    Hello, first time poster:I have a small object 2x3x1 inches. The object is not symmetrical at all. When I do a turntable scan (20 steps - just for kicks) everything looks great. I then flip the object over to get data on the unprocessed underside of the object with an additional scan. Another great scan occurs, but every single time I try to merge the two scans (just pressing the green checkmark) I get a flipped (180 degrees) version of my object superimposed on my original. I would think that there is definitely enough data to align the two no problem, but it just doesn't. I can manually align, but I hate doing that because I feel like it doesn't turn out as well. If I were to just rotate the object, and not flip it, for additional scans, it works as it should. I could of sworn I read somebody else having this issue, but I can't remember what their work around was. Any tips?Thanks a ton!Dr Fill
    Similar problem, would be glad to know the solution
  4. #4
    Student
    Dec 2021
    Location
    Germany, Schleswig-Holstein
    Have you tried to scan with the maximum of steps (36)? And did you tried with manual brightness settings or HDR?
