Flash Forge Inventor II Spring Promotion
    Primer/filler needed
    I want to get a good primer for a current project. Ideally I'd like to get a primer that can also file any gap or layers that I can't sand out. So basically sand, primer, sand again, primer and then paint. Any tips? Needs to be available in the UK.
    Cheers
    I print plugs to make composite molds. I use a lot of polyester primer on my prints. its high build and sands easy. smooths out a lot of the small imperfections. I use Evercoat feather fill. But not sure if you can get that brand in the UK. I sometimes use some bulldog adhesion promoter first on the bare ABS. Just to ensure the primer bonds well to the ABS.
