Results 11 to 16 of 16
Thread: QIDI 1 surging fan
09-29-2016, 01:12 AM #11
No need to be rude.
Educate yourself.
Glad you found the issue with the fan.
For the fan issue in the file itself as I stated and posted a screen shot for you, Simply 3D allows you to control the fan speed layer by layer of you want.
I setup OctoPrint on an RPi (hence the name OctoPi) and send my files to be printed directly to the printer through that instead of the SD card route.
It does not like the x3g files and instead uses the gcode files. S3D has the ability to save both the x3g and the gcode file at the same time.
Fan on/off and speed settings work on the gcode file. The x3g its either on or off. I've not looked into seeing if you can pack the speed control in the x3g file.
Glad your up and running again. Enjoy.
Editor in Chief
Bitsonline
09-29-2016, 07:27 PM #12
- Sep 2016
- 7
09-29-2016, 08:25 PM #13
The fan that is the blower on the nozzles will vary in speed. S3D does allow that. it is not either on or off only as far as I have been able to see. I used PLA/PHA just last night to build the adjustable platform jack model and had the fan at 20% for the first 4 layers and at 100% for the rest. The fan did spin at a slower speed during the first four layers. Why?? I am not sure as it is not a 3 pin fan power connection that usually controls fans. I have not disassembled the unit to check the board but the control board may very well control the fan speed by adjusting the amount of power it sends to it. I will take it apart in the coming weeks and find out.
As far as being upset by your rude reply yes I was.
Editor in Chief
Bitsonline
09-29-2016, 10:44 PM #14
- Sep 2016
- 7
@bitcoin.com boy
The message you seemed to have taken as "rude" wasn't for you. I was trying to end a thread that *I* started. Quit busting my balls about the fan shit. Since you appear to so desperately need the last word, it's yours.
09-30-2016, 11:04 AM #15
Time for everybody to just back away from this one...
- Moderator
10-01-2016, 01:42 AM #16
