Results 1 to 10 of 19
Thread: Hinged Ganry with ABL probe
08-26-2016, 08:23 AM #1
- Dec 2014
- Canada
- 498
Working on a new CoreXY printer
and was hoping you guys could give me your two cents on the basic idea of how ABL is handled in this gantry design
A Special gantry for openbuilds vslot using Mini V wheels
it also include the ABL (Auto Bed Levelling) Micro switch so when pressure is applied to the nozzle it hinged upward slightly to trigger the microswitch
http://www.thingiverse.com/thing:1737901
Video https://youtu.be/MJS9SiPSY3Y
08-26-2016, 10:12 AM #2
Do you have one working? Do you get good M48 numbers? Is that spring in the center where you set how much force it takes to lift up gantry?
08-26-2016, 02:10 PM #3
- Dec 2014
- Canada
- 498
Haven't had time to test it. But it only needs to lift a tiny amount to trigger the switch. And yes spring is to set tension
09-12-2016, 11:48 PM #4
- Dec 2014
- Canada
- 498
Here is it working. https://youtu.be/Iq-L2mW2IyM
09-13-2016, 10:28 AM #5
Let's see it doing an M48 V4 P10 !!! This is a very elegant design. The only thing that I'm not sure about is whether I can use it. I really need to have my heat bed on springs because any firmware mistake drives the nozzle into the bed and I need a little bit of extra flex so I have time to press the reset button. I guess if my heat bed springs don't deflect as easily as the nozzle deflects, I might still be able to make it work for me.
09-13-2016, 10:40 AM #6
- Dec 2014
- Canada
- 498
Well my bed is completely solid. and my Gantry cant go down that far. it hits a physical limit.
if it tried to drive down.. the spring would take up the pressure.
I will try the M48 V4 P10 when I get home
09-13-2016, 09:30 PM #7
- Jul 2014
- 305
This seems very similar to the Atom 2.0 Printer:
https://www.youtube.com/watch?v=ygHrhfxhx38
It has its ABL sensor triggering in the same manner.
09-13-2016, 10:20 PM #8
- Dec 2014
- Canada
- 498
Yep, that printer inspired me to make this version.
09-13-2016, 10:31 PM #9
- Jul 2014
- 305
09-14-2016, 10:16 AM #10
- Dec 2014
- Canada
- 498
Havent had a chance to really print with it yet. been testing and tweaking so many things related to the printer..
but I will very soon i hope
