Results 1 to 10 of 14
04-17-2016, 08:51 AM #1
Qidi Tech 1 Simplify 3D Startup Script
In Simplify 3D when you select the Flashforge Creator Pro profile the default startup script creates a blob of plastic on the right side of the build platform. If you replace the starting scripts with these it will extrude a line of plastic along the front of the build platform to make sure the extruder is properly primed.
This script was buried in the massive Qidi Tech thread, I thought it would be easier to reference if we made it its own thread.
http://3dprintboard.com/showthread.p...ll=1#post83647
Paste this under the Left Extruder startup script
Code:; **** Qidi Tech Left Extruder start.gcode **** M73 P0 ; Enable build progress G162 X Y F3000 ; Home XY maximum G161 Z F1200 ; Home Z minimum G92 Z-5 ; Set Z to -5 G1 Z0 ; Move Z to 0 G161 Z F100 ; Home Z slowly M132 X Y Z A B ; Recall home offsets M135 T1 ; Load left extruder offsets G1 X-100 Y-75 Z30 F9000 ; Move to wait position off table G130 X20 Y20 Z20 A20 B20 ; Lower stepper Vrefs while heating M126 S[fan_speed_pwm] ; Set fan speed M140 S[bed0_temperature] T0 ; Heat buildplate M134 T0 ; Stabilize bed temperature M104 S[extruder1_temperature] T1 ; Heat left extruder M133 T1 ; Stabilize left extruder temperature G130 X80 Y80 Z40 A80 B80 ; Default stepper Vrefs G92 A0 B0 ; Zero extruders M135 T1 ; Load left extruder offsets G1 X-100 Y-65 F9000 ; Move to front left corner of bed G1 Z0.3 F6000 ; Move down to purge G1 X90 Y-65 E24 F2000 ; Extrude a line of filament across the front edge of the bed G1 X100 Y-65 F180 ; Wait for ooze G1 X110 Y-65 F5000 ; Fast wipe G1 Z1 F100 ; Lift G92 A0 B0 ; zero extruders M73 P1 ;@body (notify GPX body has started) ; **** end of start.gcode ****
Paste this under the Right Extruder startup script
Code:; **** Qidi Tech Right Extruder start.gcode **** M73 P0 ; Enable build progress G162 X Y F3000 ; Home XY maximum G161 Z F1200 ; Home Z minimum G92 Z-5 ; Set Z to -5 G1 Z0 ; Move Z to 0 G161 Z F100 ; Home Z slowly M132 X Y Z A B ; Recall home offsets M135 T0 ; Load right extruder offsets G1 X-100 Y-75 Z30 F9000 ; Move to wait position off table G130 X20 Y20 Z20 A20 B20 ; Lower stepper Vrefs while heating M126 S[fan_speed_pwm] ; Set fan speed M140 S[bed0_temperature] T0 ; Heat buildplate M134 T0 ; Stabilize bed temperature M104 S[extruder0_temperature] T0 ; Heat right extruder M133 T0 ; Stabilize extruder temperature G130 X80 Y80 Z40 A80 B80 ; Default stepper Vref G92 A0 B0 ; Zero extruders G1 X100 Y-70 F9000 ; Move to front right corner of bed G1 Z0.3 F6000 ; Move down to purge G1 X-90 Y-70 E24 F2000 ; Extrude a line of filament across the front edge of the bed G1 X-100 Y-70 F180 ; Wait for ooze G1 X-110 Y-70 F5000 ; Fast wipe G1 Z0.5 F100 ; Lift G92 A0 B0 ; Zero extruders M73 P1 ;@body (notify GPX body has started) ; **** end of start.gcode ****
Code:; **** Qidi Tech Both Extruders start.gcode **** M73 P0 ; Enable build progress G162 X Y F3000 ; Home XY maximum G161 Z F1200 ; Home Z minimum G92 Z-5 ; Set Z to -5 G1 Z0 ; Move Z to 0 G161 Z F100 ; Home Z slowly M132 X Y Z A B ; Recall home offsets M135 T0 ; Load right extruder offsets G1 X-100 Y-75 Z30 F9000 ; Move to wait position off table G130 X20 Y20 Z20 A20 B20 ; Lower stepper Vrefs while heating M126 S[fan_speed_pwm] ; Set fan speed M140 S[bed0_temperature] T0 ; Heat buildplate M134 T0 ; Stabilize bed temperature M104 S[extruder0_temperature] T0 ; Heat right extruder M104 S[extruder1_temperature] T1 ; Heat left extruder M133 T0 ; Stabilize right extruder temperature M133 T1 ; Stabilize left extruder temperature G130 X80 Y80 Z40 A80 B80 ; Default stepper Vrefs G92 A0 B0 ; Zero extruders G1 X100 Y-70 F9000 ; Move to front right corner of bed G1 Z0.3 F6000 ; Move down to purge G1 X-90 Y-70 E24 F2000 ; Extrude a line of filament across the front edge of the bed G1 X-100 Y-70 F180 ; Wait for ooze G1 X-110 Y-70 F5000 ; Fast wipe G1 Z0.5 F100 ; Lift G92 A0 B0 ; Zero extruders M135 T1 ; Load left extruder offsets G1 X-100 Y-65 F9000 ; Move to front left corner of bed G1 Z0.3 F6000 ; Move down to purge G1 X90 Y-65 E24 F2000 ; Extrude a line of filament across the front edge of the bed G1 X100 Y-65 F180 ; Wait for ooze G1 X110 Y-65 F5000 ; Fast wipe G1 Z1 F100 ; Lift G92 A0 B0 ; Zero extruders M73 P1 ;@body (notify GPX body has started) ; **** end of start.gcode ****
05-22-2016, 07:40 PM #2
I just updated the scripts to change the default VRefs to 80 instead of 127.
Changed this line:
G130 X127 Y127 Z40 A127 B127 ; Default stepper Vrefs
http://3dprintboard.com/showthread.p...ll=1#post88762
Alternatively you could change the VREFs in the EEPROM using Replicator G and remove the lines from the scripts altogether.Last edited by KludgeGuru; 05-22-2016 at 08:14 PM.
06-02-2016, 02:30 PM #3
- May 2016
- 55
This would be a good thing to put in the QIDI group as well. It's also useful for people who haven't shelled out for Simplify, as G-code is G-code (for the most part).
07-12-2016, 09:41 AM #4
- May 2016
- 55
I've modified these for Slic3r, if anyone's interested.
07-23-2016, 10:13 PM #5
- May 2016
- Annapolis, MD
- 523
I've noticed that when I am printing with a single extruder, the unused extruder still gets very warm. Perhaps a change to the GCode scripts would be appropriate? The changes I suggest are shown below. Any reasons not to do this?
For the Left Extruder:
Change From - G130 X80 Y80 Z40 A80 B80 ; Default stepper Vrefs
Change To - G130 X80 Y80 Z40 A05 B80 ; Default stepper Vrefs with unused Right extruder at idle
For the Right Extruder:
Change To - G130 X80 Y80 Z40 A80 B05 ; Default stepper Vrefs with unused Left extruder at idle
No changes are needed within the Both Extruders script
08-06-2016, 09:39 AM #6
- Aug 2015
- 10
FYI the latest Simplify3d update (June 2016 ver 3.1.0) includes a profile for the Qidi Tech 1 in it's printer model choices. I haven't compared all the settings to the ones listed in this thread, but it seems to work well for me.
09-04-2016, 09:59 PM #7Editor in Chief
Bitsonline
01-22-2017, 09:27 PM #8
- Jan 2017
I know this is not the exact printer but I am looking for this same information for the QIDI X-ONE to be used in Cura. Any help would be appreciated - trying to get a head start on the setup just ordered this printer today from Amazon.
01-24-2017, 07:37 PM #9
- Jan 2017
Hello all- new here to the forum and just bought a QIDI X-One. I'm looking for some direction here please. So I hate the stock software that the X1 came with and want to use Cura (2.3.1) which I am accustomed to. I'm looking to get the proper info set up in Cura for the best prints. I can't seem to find any post pertaining to this printer. I know Simplify 3D supports this printer but really did not want to spend 150$ on software. Any help would be appreciated....
John
01-24-2017, 07:38 PM #10
- Jan 2017
Or if anyone have Simplify 3D I would love to see the setting it has for this printer so I can use Cura which I as used to... Thanks you all.
QIDI Slicer "Plater" is...
