Results 1 to 10 of 13
Thread: CTC printer settings
01-30-2016, 04:52 PM #1
- Jan 2016
- 10
Hi, Can someone please tell me what the factory offset settings are for my printer when it is first set up ?
I upgraded to sailfish and forgot to write them down.
Now my printer hits the left side and clicks a few times after it prints the purge line across the front at the start of print. I have noticed it doesn't always do this, but most of the time it does.
My printer is the one pictured
printer.jpgLast edited by Kokobi; 01-30-2016 at 06:13 PM.
01-31-2016, 05:08 AM #2
- Dec 2015
- Seattle
- 38
IIRC it was 34mm (which changed to 33.96mm when the printer reset.)
01-31-2016, 07:07 AM #3
- Jan 2016
- 10
01-31-2016, 07:09 AM #4
- Dec 2015
- Seattle
- 38
IIRC == If I Recall Correctly.
01-31-2016, 08:10 AM #5
01-31-2016, 07:05 AM #6
02-01-2016, 04:20 PM #7
- Jan 2016
- 10
02-01-2016, 05:02 PM #8
Yes, those settings were copied directly from a working default Makerbot-2.4 Profile
and I can Not find any other related settings there.
(I will try to find related settings in my Rep-G, may be tomorrow though,
since I no longer use Rep-G and Python-interpreter but still have it on another computer)
I don't understand what the X-toolhead setting of 33.992 could be ???
There's nothing like that in Makerbot-2.4
and the Z-offset should start at zero then move to .2
(Maybe the X-toolhead setting was for a CNC-machine, not a printer ?)
I'll try to find that also.Last edited by EagleSeven; 02-01-2016 at 05:38 PM.
02-02-2016, 07:15 AM #9
Well I tried to get Rep-G G & M code list from the old computer this morning
but for some reason Rep-G could not find Python interpreter.
I don't think I uninstalled it, so don't know what happened ??
So, I don't think I'll be able to look for setting codes in Rep-G, Sorry !
I suggest that you use Makerbot-2.4 slicer, It's much easier to use than Rep-G,
when computer is connected directly to printer through USB cable.
2.4 is great after you find all the Hidden stuff in it
Note: I've had problems with later versions of Makerware,
so still use version 2.4, that came with printer on SDLast edited by EagleSeven; 02-02-2016 at 07:25 AM.
02-02-2016, 09:31 AM #10
- Dec 2015
- Seattle
- 38
It's the tool head offset (For those wondering I mean the distance between the extruders) . When I updated to Sailfish, all of my home axis remained, but my tool head offset had been set to 0, so when the printer used the left nozzle it went way left and started clicking before attempting to print.
QIDI Slicer "Plater" is...
