Results 71 to 80 of 84
06-12-2016, 12:29 AM #71
- May 2016
- Annapolis, MD
- 523
That's a good catch Scobo. A well positioned factoid in their data sheet, like the very last note on the page...
06-12-2016, 02:11 AM #72
- Jul 2014
- UK
- 124
06-13-2016, 07:03 AM #73
06-13-2016, 09:25 AM #74
06-07-2017, 09:47 PM #75
- May 2016
- Annapolis, MD
- 523
I have been using the Toshiba Air card setup with my QiDi for about a year now. I love it. It has been rock solid. HOWEVER, I have one more gold plated caveat to add to the list of Toshiba Air Card "gotchas".
DO NOT attempt to move a file over WiFi onto the Toshiba Air Card that includes an "&" embedded in the file name. Example: "Nuts&Honey".
Windows is fine with this, and the file system on the SD card is fine with this, but the Toshiba code that deals with comms to/from the card goes bats. I seem to recall that DOS utilized the "&" as kind of an "Escape" character, maybe something like that is going on... Anyway, the file save will fail, and the card's "Files" directory will become inaccessible via WiFi. Take the card out and directly access via some SD dongle from your computer to change the filename to one without the offensive "&". All will be well.
I feel like a freaking idiot for not approaching it from the "What was the last thing you did" perspective. Took me about 30 minutes of ripping things apart and incrementally rebuilding it all to get it. I finally got the (in your face) clue when I saved the same file I had been trying to save previously, and everything promptly went straight south in a handbasket once again. Faceplant...
06-08-2017, 01:15 AM #76
- Jul 2014
- UK
- 124
Thanks for the heads-up there. I'll be sure to avoid that one !
06-08-2017, 06:08 AM #77
10-25-2017, 06:23 AM #78
- Oct 2017
As a heads-up, Toshiba has released a W-04 version of these cards that has a few new scripting features (mostly useless for most printers, but could be useful if you're running MachineKit, LinuxCNC, OctoPrint, etc. with one of these in it for some reason, or if you've got the resources on your board to run a modified firmware that can leverage them), more resources for the microcontroller (and some flexibility in how they're used), and improved WiFi connectivity. The throughput is 2.9x higher on the WiFi side (again, not a huge issue for most use cases with 3D printing) and the connection itself is stronger and more resilient. They're also designed to leverage UHS-I Class 3 and the SDXC standard (both pretty much completely useless for 3D printers).
Some folks who've had issues with these cards may have been too far from their AP, but the new design should increase the range a little bit when inside a metal box (they say camera body, we say 3D printer, both are a potential issue). The new WiFi engine is specifically designed for better performance in noisy environments, which 3D printers themselves are, as are areas with medium to high population density these days (I can see dozens of networks from some rooms of my house, which is the problem they were solving for).
I'll have one on Friday and expect to have it configured and running by the weekend, if all goes well.
10-26-2017, 08:54 PM #79
- May 2016
- Annapolis, MD
- 523
11-16-2017, 06:08 PM #80
- May 2016
- Annapolis, MD
- 523
AI generated 3d models -...
04-12-2024, 11:54 AM in 3D Modeling, Design, Scanners
