Results 11 to 17 of 17
Thread: Ideas
01-28-2016, 06:58 PM #11
- 26
On the new Peachy Printer board. It looks like the dripper system has a built in simple but very effective siphon in the dripper system to drain the salt water
http://peachyprinter.ipbhost.com/ind...dripper-video/
https://m.youtube.com/watch?v=V98DUS0hWxo
01-28-2016, 07:58 PM #12
- Sep 2013
- 308
yes the way we have arranged the hoses solves many problems
by learning a simple sequence of plugging hoses and reservoir positions the new drip bubler system dose all of the following:
- you can start the dripper by squeezing the bottle
- you can start lower the water level by squeezing the bottle and placing the upper reservoir below the printer.
- the siphon hose that lowers the water to in order to reset the rprinter for a new print will automatically loose siphon at the correct height to start a print.
- if all hose heights are properly maintained resin will not be picked up an brought to the upper reservoir.
- The top resivour has a lid so its harder to spill
- the driper is now an open air design so it is very easy to clean ( salt crystals will build up on the dripper)
- the drip bubler system ensures a steady pressure to the dripper so if you start a print at 5 drips per second, it will hold that drip rate for the duration of the print.
- pausing a print is as easy as its always been you just crimp a hose.
-a water flow resistor in the hoses make is possible to change the drip rate from .5 drip per second to 8 drips per second by changing the height of the upper reservoir by just a few inches.
- an air flow resistor makes the size of the bubbles smaller ensuring a very smooth flow rate to the dripper.
The post linked to above is a very ruff draft of the instructions on how to use the dripper and how it works. more work will be done on it soon.
01-28-2016, 11:22 PM #13
- Jan 2016
- 11
rather than use those rings I was looking at these:
found them here: http://www.rebelbrewer.com/shop/brew...ng-thumb-clamp
01-29-2016, 01:50 AM #14
- May 2014
- 17
You can just find a printable version of those hose clambs
http://www.thingiverse.com/thing:28447
01-29-2016, 09:33 AM #15
- Sep 2013
- 308
01-29-2016, 12:28 PM #16
- Jan 2016
- 11
Yes printing some would be my choice and was looking but with a ridged resin this style would not work so I am looking at some other designs. Also I was throwing it out there more for the customers to see other options, I agree that keeping the initial price as low as possible is a top priority.
01-29-2016, 05:38 PM #17
- Apr 2014
- 88
