Results 1 to 10 of 12
Thread: Flashforge filament not sticking
11-18-2015, 10:05 AM #1
- Nov 2015
- 2
Hello-
I have a new Flash Forge Creator Pro. I am trying to print the traffic cone that is preloaded on the SD card. Right now the ABS pools up on the extruder and does not stick to the bed. Any suggestions? The bed is level. Thanks in advance.
11-18-2015, 10:48 AM #2
- Sep 2015
- San Pedro, CA
- 66
Clean the bed REALLY well and confirm z height. I found using a paper towel and rubbing alcohol on blue tape works. On glass, I use a squeegee.
Confirm layer height and make sure the first layer is getting a bit smooshed.
Mo
www.LAfilament.com
11-18-2015, 10:56 AM #3
- Nov 2015
- 2
What should the Z height be set at?
11-18-2015, 11:16 AM #4
- Sep 2015
- San Pedro, CA
- 66
The rule of thumb I see stated is to fold a piece of paper in half and slide it under the nozzle. It should grab/drag.
I use a business card I have lying around for the same purpose...
Mo
www.LAfilament.com
11-18-2015, 11:51 AM #5
business card is generally too thick. I use 90gsm (business cards are usually between 200-400 gsm) paper.
Also you need something coating the printbed: hairspray, blue tape, glue stick etc.
People do get abs to stick to kapton (what the bed comes covered with) but I never managed it :-)
11-18-2015, 12:19 PM #6
11-18-2015, 03:33 PM #7
- Aug 2015
- 256
11-18-2015, 06:13 PM #8
I recommend you clean your bed with spray (3DLac) or Builtak so your filament will stick to your ABS material.
11-18-2015, 06:54 PM #9
- Feb 2015
- 91
For a brand new printer with a brand new print bed assuming nothing is physically broken, the problem has to be (with >90% probability) that the bed isn't close enough to the nozzle. It's a little unfortunate that we call it "level build plate". Technically what we're doing is "tramming" that is making sure the bed is parallel to the print head motion.
But for beginners printing small parts at the center of the bed, even more important than "level" is how far. Because the code isn't big enough to notice much tilt in the bed, it's more important how far away the bed is. I think that's why beginners get confused by the "leveling" terminology and say things like "the bed is level".
Yes, it may be "level" but it is "level" too far away. When the printer commands Z=0.2mm for that first layer, it needs to be pretty close to 0.2mm because the extrusion has to hit the bed to stick.
I think that sample part was sliced with ReplicatorG which assumes that you are actually at 0.25mm away when z=0.2mm which provides for a 0.05mm piece of paper. Many slicers however assume that it matches precisely. It should be ok +/- 0.5mm it's just the first layer will be either underextruded (adjacent lines won't stick to each other) or over extruded (elephant foot). Beyond that, it's likely to have problems not sticking either because the head isn't squishing it much and/or it's running into the over extrusions and cleaning the print up into a ball on the nozzle.
12-03-2015, 11:42 AM #10
- Feb 2015
- 2
Is this why I can't print anything without a raft?
Trying to make letters of the...
03-22-2023, 09:57 AM in General 3D Printing Discussion
