Results 1 to 9 of 9
10-05-2015, 05:59 AM #1
- Oct 2015
- 10
Tinyboy 3D Printer for Kids and Students designed from Hong Kong
http://www.thingiverse.com/thing:969645
Video :
https://www.youtube.com/watch?v=RVLiUBf1iGY
https://www.youtube.com/watch?v=KViu0PyYcm8
https://www.youtube.com/watch?v=_rW9SUn5Eho
Original design by http://www.thingiverse.com/thing:701548
Remixed from http://www.thingiverse.com/thing:776896
and http://www.thingiverse.com/thing:880110
OLED by http://www.thingiverse.com/thing:816376
This module can be used on every arduino mega ramps 1.4.
with Marlin version.
Updated :
- Arduino Mega 2560 + RAMPS + 4 x A4988 (Cheaper costs)
- LM4UU Bearing (Smoother movement)
- 2GT 16 tooth Gear (Easy Setting from Marlin)
- GT2 Belt
- OLED Display /w Tinyboy Splash Logo (Display Info)
- TF Card Module (Offline Printing)
- 4mm Thickness Acrylic Case (Stable Support)
- 3 x 35 Stepper 0.9 degree per step (Stable Movement)
- Bed Leveling using sping
http://www.HKMakers.hk
TinyBoy Website:
http://www.tinyboy3dp.net/
FaceBook:
https://www.facebook.com/tinyboy3dp
Supporting Organisation:
Hong Kong Creative Open Technology Association (HKCOTA)
Opensource Hong Kong (OSHK)
Hong Kong Linux User Group (HKLUG)
Less is more
The maximum size of printed object is 8 x 8 x 8cm , which is relatively small than many other 3D printer. However, it is already large enough for making things like figure and toy.
The gain from the trade off is the cost down of material and maintenance. Take out components for making large printed object , the design become simple and lean. The core material is acrylic sheet and connected by metal screw. Therefore , the cost of material and building can be minimized.
Easy to build / Learning by making
The process of making has the opportunity to transform education by inviting students to be something other than consumers of education. They can be maker of anything , moving from being directed to self-directed through the process.
Tinyboy is designed for easy to build. The assemble from kit can be done by just using a screw driver. We wish student can make their own machine. Then they become a pioneer whose may make another one for other people. So that the use of 3D printer can be spread out to more student.
The case of TinyBoy uses acrylic plane as the main material. Individual parts can be made by using cutter laser. Therefore, the manufacturing process is easy once you have a laser cutter. In fact , the price of an A5 laser cutter can be as cheap as USD $400. That make the cost of small amount production be reasonably low.
Specification
Size: 15cm(W) x 15cm(D) x 22cm(H) (excl. filament holder)
Printed size : 8cm x 8cm x 8cm
1.75mm filament / 0.4mm hotend
Contributors
Parker Leung (Designer)
Wan Leung Wong
Haggen So
Henry Law
TC Liu
Ben Lau (Honourable)
12-14-2015, 07:11 AM #2
- Oct 2015
- 10
Added support for Bluetooth and Wifi .
12-14-2015, 08:24 AM #3
12-14-2015, 08:59 AM #4
- Oct 2015
- 10
the printer is 150mm x 150mm x 240mm which is small enough for Kids to handle while Year 4 to Year 12 from primary/secondary school are the best..
the maximum print size is only 80mm x 80mm x 80mm but can make a robot figture with joint for about 400mm in height.
robot figure can find from www.tinkerplay.com
05-03-2019, 05:27 AM #5
- May 2019
How much is the general cost ?
05-03-2019, 11:50 PM #6
- Oct 2015
- 10
from Primary up to Univerity grade for studying by Assembly the 3D Printer themselves
05-03-2019, 11:50 PM #7
- Oct 2015
- 10
please visit from our website www.HKMakers.hk or www.tinyboy.net
05-05-2019, 12:58 PM #8
what does it cost ?
Absolutely no clue on your website - which is apparently stuck in 2016.
Also no specifications, or indication why having an exposed hotend they can poke is good for kids.
05-05-2019, 08:55 PM #9
- Oct 2015
- 10
we have got a fan cover on the hotend to prevent touch of it.
www.tinyboy.net is our inital project page since 2013~2016 with TinyBoy 1 ~ TinyBoy 2
you can check the tinyboy details on http://hkmakers.hk/tw/23-tinyboy
or look at our recent events from http://www.facebook.com/hkmakers.hk
or contact us at fred@cocohost.com directly
Regards
Which 3d printer for small...
03-27-2024, 05:24 PM in General 3D Printing Discussion
