Results 1 to 6 of 6
09-04-2015, 10:17 AM #1
- Aug 2015
- 10
Filament that will hold up in window of hot car?
I made a custom mount for something in my car... came out perfect. Now I know that PLA won't hold up in a closed car in the Arizona sun... sagged. Will nylon hold up in heat or will another filament? Or, do I need to use the CNC mill and aluminum?
09-04-2015, 11:06 AM #2
You could print in polycarbonate or PEEK.
09-04-2015, 07:32 PM #3
nylon will hold up - good luck printing with it, it's a total bastard.
The new coffe pla from protopasta is good for more than 100c.
Just how hot does your car window get ?
09-04-2015, 07:55 PM #4
- Oct 2013
- new jersey
- 752
Use the new epc filament from esun. Is a liw warp polycarb blend. Higher temp than abs, more rigid and very easy to print with.
09-07-2015, 10:38 PM #5
taulman3D's BluPrint is designed to have a high heat deflection. I'm not sure how hot the dash of a car may get, but taulman3D states this product will sustain boiling water for 5 continuous hours.
We carry this product in sample form if you'd like to give it a try.
BluPrint - BluPrint is a specialty polymer developed to specifically handle High Heat Deflection requirements. With a Tg of 110C and a print temp of only 265C, BluPrint is an easy to print polymer that comes as a clear material similar to t-glase.
Potential uses:
Lamp covers
Antique car/item lenes or ligh covers, i.e. tail light, turn sig, etc..
Any use in high heat environment
Thermal spacers
Thermal Clamps
Any part that will need to be placed in boiling water for preparation.
BluPrint can sustain boiling water for 5 continuous hours. Clarity will be lost after 2 hours to a dull haze. Structure will be maintained.
09-08-2015, 05:48 AM #6
well bear in mind that what taulman considers an 'easy to use filament' is easy to use ONLY if you have a fully enclosed industrial printer. I find most of their stuff almost unusable on a standard unenclosed desktop machine.
QIDI Slicer "Plater" is...
