Results 1 to 8 of 8
08-20-2015, 06:06 PM #1
Printing with silver ABS different than red ABS?
I am printing a circular medallion and when I print it with Hatchbox red ABS, it prints just fine. When I print it with Hatchbox silver ABS, the raft starts to curl and the edges of the medallion curl. I tried lowering the bed temp (printing red at 225/107) to 105 and 100 and it still happens. Any tips on printing with this type of filament? I am at a loss.
08-21-2015, 02:02 AM #2
Different filaments have different properties, even if they are both ABS. wrt peeling/warping: is your chamber enclosed? It should be for ABS.
08-21-2015, 07:04 AM #3
The typical rainbow colors from the same vendor (if a quality vendor) should all print similarly.
For White, Grey, Black and Silver, there are a variety of coloring agents that might be used; some may require higher or lower temperatures.
08-22-2015, 10:32 AM #4
08-22-2015, 10:34 AM #5
08-24-2015, 06:37 AM #6
In my experience, just the extruder.
09-02-2015, 10:20 AM #7
- Sep 2015
- 12
When printing with ABS if a curl is observed you should have increased the temperature, not reduced.
09-02-2015, 11:58 PM #8
Based in my experience, you should increase your temperature when 3d printing Silver filaments, even if you're using ABS material.
QIDI Slicer "Plater" is...
