Results 2,871 to 2,880 of 4110
08-19-2016, 01:38 PM #2871
Thermocouple shouldn't affect blocks or height.
Ya depending on the heater and thermocouple position there could be some differences in readings. That is just bad heater block design. That's why my heater blocks are compact and the nozzle and heating element are very close together.
08-19-2016, 01:43 PM #2872
- Aug 2016
- 11
08-19-2016, 01:55 PM #2873
I don't wrap them, since the overall heater block is smaller there is less heat dwell from the block and this helps plastic cooling. One of the reasons blocks are wrapped is heat dwell. Where the heater block is so big and hot it can actually melt the plastic from radiated heat or at least keep it softer than it should be.
But you can wrap them if you want.
08-19-2016, 02:13 PM #2874
- Aug 2016
- 11
08-19-2016, 02:27 PM #2875
- Jun 2016
- Oklahoma
- 904
OK!! The new QIDI X-ONE.
I have a bunch of parts that are well within the size of this one. Load them up and let it go. They had a good introductory price and shipped free from the USA.
The software I think is a version from Cura. Pretty good to get going with.
Set up was not a big deal and printer was packed excellent.
First print is their test "cube" pillar. 1mm X 1mm X 50mm and the size is almost dead on.
[IMG][/IMG][IMG][/IMG][IMG][/IMG]
08-19-2016, 02:37 PM #2876
What's the build size of that?
And that doesn't look 1mm x 1mm anywhere. lol
08-19-2016, 02:48 PM #2877
- Jun 2016
- Oklahoma
- 904
08-19-2016, 03:23 PM #2878
- May 2016
- Annapolis, MD
- 523
All right W! I guess you qualify as a true "blue" QiDi user. <grin> From now on I guess we will have to specify which QiDi printer model is being discussed. I like the look of the control panel. From your pix it looks to be the same basic drive design. Does it use 8mm or 10mm rods for x, y & z?
08-19-2016, 03:45 PM #2879
- Jun 2016
- Oklahoma
- 904
It all looks to be a narrower (X-axis), single extruder version. Otherwise everything really looks the same. Rod sizes are the same.
So far it is printing nice. This could be a good one for just doing those jobs and don't mess with the printer to much, just let it run. This looks like it could be a great starter printer that is fairly straight forward but still high quality. We will see over time but so far it is delivering.
The software is definitely usable and with a fair amount of control.
I have been in contact with S3D and QIDI who said they were going to get with S3D. No sooner did I tell the guy at S3D he emailed back and said they (QIDI) had just gotten a hold of them about the printer. S3D is excited to work with it and get things rolling so support from both so far has been great.
08-19-2016, 04:00 PM #2880
- May 2016
- Annapolis, MD
- 523
What's wrong with this prting?
04-14-2024, 05:15 PM in General 3D Printing Discussion
