  1. #1
    calculate weight of 3d printed object
    Hello,
    Help, please.
    I want to calculate the weight of an object prior to printing.
    I asked a couple of filament manufacturers but received no response.
    I am trying to get my formulas right before hand.
    density = mass/volume
    volume = density * mass
    The print area on printer is 300mm X 300mm X 420mm
    Which gives a total volume of 37,800,000mm3 OR
    3,780,000cm3.
    The density of polycarbonate is 1.20g/cm3.
    so, the weight of a full build would be:
    3780000 * 1.20 = 4,536,000g
    4,536,000g /453.592 = 10,000.17lbs (is that right??)
    I don't think any of these hobby 3d printers could handle a 5ton print.
    Where did I go wrong?
    Thank You.
  2. #2
    Engineer ralphzoontjens's Avatar
    Nov 2013
    Location
    Tilburg, the Netherlands
    Follow ralphzoontjens On Twitter Add ralphzoontjens on Facebook Add ralphzoontjens on Shapeways Add ralphzoontjens on Thingiverse
    Lol, one cm3 is 1,000 mm3.
    Most slicers will also do this for you taking into account wall thickness and infill amount.
