06-11-2015, 12:33 PM #1
- Jun 2015
Large bulb of ABS filament attached to extruder (Makerbot Repllicator 2X)
I have a Makerbot Relicator 2x and have encountered an issue that I need to fix.
I irresponsibly left it unattended for ~1hr and when I returned, I found that the filament had not left the extruder properly and is now firmly attached to the extruder. Has anyone ever encountered this before and know of a way to remedy the situation?
Thanks in advance
Picture for reference:
06-11-2015, 04:44 PM #2
- 462
Can you heat up the hot ends to loosen it?
06-12-2015, 02:05 AM #3
Happend to me before on a printrbot. Heat the hot ends and start prying bits off with a needle nose plier.
06-12-2015, 05:20 AM #4
oh yeah been there several times.
Get the extruder hot and just pull, pick and yank it all off.
Should work fine after that.
Doesn't look like you've got much there.
